Servicing Your V35 - List Of Whats Needed
When I put the engine in last time I hated that every piece of aluminum looked different, I took every thing to adept metal polishing and got them all satin polished (basically brushed) turbo before and after plenum before and after, I got everything else done as well, these photos just show the biggest difference
Further result update. This is from our ATR43SS3 model in T3 .63 rear housing, run against None Geninue G30-770 and 900 spec turbochargers in T3. 82 turbine housing. Those turbos are ideal for RB25det motors, Since I've got a bullet proof RB30det, its been used as test bed instead. All three turbos run to a point that no more boost could be held and no more power could be made. Same test car and exact vehich setup as been used testing all three turbos:
