Caliper Painting Guide (brembo)
Fanta R33GTR
So, I decided a few weeks ago to paint my brembo brakes on my GTR. They were all chipped due to stones, it is a 1996 after all. The last 2 years on NZ roads probably did more damage then it's entire life in Japan :)
To begin, mask off everything, and wash down the calipers with hot soapy water.
You'll need some Brembo stencils. Any shop that makes decals will be able to do this for you.
Paint Stripper
Brembo Stencils
After the first application of the stipper
You may need to apply the stripper several times to clean off the factory paint.
After all the paint is off, sand back the calipers with 400 grit wet and dry
FRONT
REAR
You can either use hi temp paint or caliper paint. I've gone with a metallic charcoal. 2 coats should do the trick
FRONT
REAR
Important !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LET THE PAINT CURE FOR A FEW DAYS BEFORE YOU PROCEED
The stencil may damage the paint if you don't
Attach the mask
Peel back the top protection of the mask.
Ready to spray the logo
FRONT
REAR
About 3 coats are nessary as the metallic charcoal is quite dark. Hi Temp White
You can apply a clear coat for a more glossy finish and extra protection.
FRONT
REAR
It takes a few days for the paint to cure properly so, best to avoid driving for a few days if you can.
That is really cool. Where did u get the BREMBO stencils from? That would be a ricers dream, fake brembos!! Can you get NISSAN ones as well?
Any shop that can make decals will be able to make this stencil. Most signwriters that use vinyal cut lettering etc. I got a local signwriter to make them for me.
Thanks
stunning work mate they look a million bucks!! nice prep work too! just finished the same sorta thing on my front rotors doing the rears in a few days ( :wub: i dont have brembos)
brembo's have very tough coatings and undercoats - paint stripper is a must on them
if you can get a good shot of the brembo writing in a jpg form, convert to vector graphics format its easy to get any sticker/vinyl shop to make them
  • 1 year later...
how long does this take in total (hours labour) and where can you find these high temp paints and clear coats from??
thanks
took around 2 hours per wheel , including preptime.
The whole project took a few days because it's important to let the paint cure
I'm actually contemplating doing mine at the moment... Want to go yellow just for something different. Any particular paint brand you would recommend? All I have been told is look for the Engine type paint (obviously for heat purposes)...
don't u need to take the caliper off? it's reli cool
1) I tried and i couldn't , too hard.
2) I had just bled the entire brak system and changed all fluids about a month ealier to this project and did not want to go through it all again :P
Looking very nice... But one question, If you went to all that effort why did you choose not to go with a different colour perhaps?
I think the dark suits the car. It's a white GTR, if i'd made it anything else like blue, red, or yellow you'll just look like a douche :)
It's personal preference I guess.
This project was more about restoring the Brembo's to the orginal state as oppossed to pimping it out.
If your car is yellow then the yellow might suit... personally I think anything apart from black or grey gives off a rice boy racer vibe and gets you the wrong kind of attention :ermm:
Get good quality spay paint. Doesn't have to be hi-temp nessesarily. If you just drive around the city and motorways the acutall calipers don't get that hot. Just amke sure to cure it properly before taking it out for a drive. otherwise all that hard work will be ruined
    • Hello, Has anyone experienced their signal light being constantly on when parking or headlights are on?   I'm putting my car back together after painting. I didn't pull out the hole chassis harness. I hooked up the chassis harness in the bay along with semi-installing a new ecu harness.   I put power to the car today to play some musicand check on thing while I worked. I noticed when I put on the parking lights that the left rear signal was constantly on. I thought for whatever reason. All the signal light needed to be install. The rear left signal did turn off after all the other signal bulbs where installed, but now the other 4 are lit. The left 2 are brighter than the right. I noticed that if u pull out the front left bulb them the left rear turns back on. Strange. Hazards work fine. Activating the signal from the stalk works. I unplugged the signal stalk power to see if that may have been the issue. Removed the fuse for the signals and they stay on constant but not blink.   I have LED 194/T10 bulbs. They're not switchback. Things worked as normal before I took thing apart and painted. The only new things I wired were two removed leads to my fuel pump relays.   Could it be the stalks? I bumped them plenty while working. Just from today I assessed them good and no flickering from contact on so it's hard to say it's the stalks.   The issue somewhere in the chassis harness?
    • You need the fuel pressure gauge reading when the car is running and on boost. Revving it stationary doesn't tell you much. Get a wideband O2 installed, or borrow a portable one. Will show very valuable data.
    • Unfortunately I kept blowing the rear twin up
    • I'm thinking this but when I checked the fuel tank the fuel strainer under the pump was as clean as new. I do have a new fuel filter I'm going to replace that hose and filter just to be safe because maybe something did get through the strainer but I'm also going to attempt at some point next weekend to get the remaining fuel out and fill it up with some high quality fuel.
