4 Dec 2005, 05:27 PM
![]() SAU VIC Member 0064 ![]() ![]() ![]() Posts: 23,551 Joined: 15th February, 2003 From: Keilor Downs Car(s): 1997 R33 GTS25TML Real Name: Paul Trader Rating : 1 Garage: GTS25t type M active LSD |
HOWTO: How to paint your standard brake calipers
Intended Audience: Anyone wishing to give their brakes a fresh colour Technical Level: Low Duration: 6 hours Effort: Small to Medium Result: High !!!Caution/Achtung/Attenzione!!! Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained herein is a guide and should be acted upon with consultation from your local tuner. If you are unsure or are not confident don't do it. The standard skyline calipers after some time can be discoloured and look a little worn or old. The best remedy for this other than buying new calipers of course is to give them a new fresh coat of paint. This gives them a fresh new look once painted and they will live happily ever after once done. Below is a step by step guide on painting your standard brake calipers and some simple hints and tips so save you some time and hassles. Tools: Suitable car jack High Temp Brake Paint Sandpaper Masking Tape Newspaper High Temp Brake Paint. $20 at Autobarn Notes: You will need 1 x Can of High Temp Brake paint to do a front set of calipers. There will be a little bit of paint left over from the front set. There won't be enough paint in the car to do the rear set so if you plan to do both you will need two cans. When you do the rear set there will be lots of paint left over in the can so you can just keep it or give it to a friend if you wish. 1. Locate the car in a suitable environment. It is recommend to leave the car standing for a few hours after spraying the calipers, over night is preferred. If you must go for a drive after a few hours of letting them dry be sure to only do a short trip and not to them up too much (ie: 5 minute drive max). It's a good idea to have some old bed sheets laying around that you can use to place over your car's guards and wheels arches so you don't accidently spray them or get overspray on them. The recommend spot would be under a carport or in the garage. 2. You need to decide if you are going to take the wheels off or not. I removed my front wheels but did not for the rear set. It is much easier if you take the wheels off and it only takes a few extra minutes to remove the wheels. This guide assumes you remove the front wheels. Find the suitable jack point for the car which is located just near the suspension tower and where the door jam area lines up. Raise the car and remove both front wheels. Be sure not to lie under the car or near the jack to prevent accidentally knocking of the jack or risk of injury from the car dropping. You can chock it up with some large pieces of wood for extra support. For the fronts you need to remove the wheels. My car has 3 spoke rims so I was able to spray the rear calieprs with the wheels on but with stock wheels you will need to remove them. 3. You need so sand down and clean the calipers. You can use normal grit sandpaper and some finer grade sandpaper after the initial sand down if you wish. I used normal grit for my ones and they came out fine. Roughly sand the caliper finish so that the surface when you rub it with your hands it feels smooth and not rough or bumpy. There is no need to completely sand off the previous colour or take it back to metal. The sanding of each caliper should only Once the calipers have a smooth finish to them you need to prepare some paper masking to prevent painting the brake calipers and components them selves. 4. Prepare a small area of newspaper (fold up a small ish area, about 1/4 of a page) to suit the size marked out in light green on the below image. Once you have folded it up to suit the area place it on top of your calipers where the pads contact with the rotors. Be sure that paper card insert you have just made perfect sits flush in this are and covers all parts of the pads / rotor and doesn't leave any uneven edges. Once it fits perfectly place some double sided or masking tape in a loop on the underside of this paper card insert and place it on the pad area so it sticks itself down. Run some extra parts of masking tap to ensure you don't miss any parts and they are even straight lines. The rest of the caliper is OK to be painted so there is no need to mask any more parts. The area marked in light green below shows the area you need to cover ![]() *** For those that wish to keep the NISSAN logo or spray it an alternate colour you need to cover the lettering now. You can use vasoline to cover the lettering, just rub it on with your fingers, clear off any excess paste and then spray over the top. Once it has been sprayed and dried you can simply rub the vasoline off and the paint over the top will come off with it, leaving the unpainted NISSAN logo underneath. You can then paint it your own colour or leave it the factory white *** Mask the other areas of your rotors and inner guards with sheets of newspaper and masking tape. Be sure to cover all areas so that only exposed areas you can see are the brake calipers. Too much paper is far better than too less. Mask all areas including the inner guards, wheel, tyre, rotors and behind the wheel also so that you don't paint the wheel arches. 5. Shake the paint can for about a minute before use, be sure to flip it upside down for about 15 seconds while shaking to mix the paint properly and swirl it all around. Once you are ready to spray hold the can approx 20cms from the brake caliper and in a slow swiping motion apply a soft coat of paint. Do not stop whilst your arm is moving in the slow swipe action. Once you have gone across the caliper stop spraying. Repeat the same process in the reverse direction. Do not stop midway through or change speed whilst moving your hand with the spray active, do it in a firm smooth motion. The first coat should take you no more than 15seconds at the most. The colour will look very faint and you will see plenty of areas that have the original colour still. It should look like a faint coat of the new colour over the top of the old one. This is correct. Do not apply any more paint at this stage. Wait approx 45 minutes to 1 hour. Go have some lunch or play a game or something. Set a timer for 50 minutes and read step 6 when the timer/buzzer goes off. 6. You need to repeat this step approx 3-4 times. Each coat should take no more than 15 seconds per caliper. 2-3 smooth swipes across the caliper and then stop. Do not hold the can in one area without your hand moving as you will get runs and blotches. Once you travel in one direction stop spray before you alternate back the other way. As you apply more coats it will become darker and it will have more colour present. Be sure to get all areas of the caliper, including the top and sides so that the paint is applied evenly and smoothly across the caliper. Once you have applied a coat, wait approx 50 minutes to an hour. Repeat step #6 at least 3 to 4 times. A can of brake paint should do a set of front calipers with a little bit of paint in the can left over. 7, Let the new paint dry for a few hours. The paint specifics state touch dry within 2 hours so be sure to leave it for a bit before you remove the masking. You can once you have let it dry remove all the masking and paper covering. You will then have a freshly painted caliper and hopefully no overspray or unpainted areas are left. Be sure to remove the top paper card insert on top of the pads and all masking tape and paper inserts. You can now put your wheel back on and do up the wheel nuts as it's fine to dry with the wheels on the car. Unpainted rear R33 brakes Painted and masked rear R33 brakes Front R33 brakes painted in gold. DBA4000 series come with gold centre already in gold Rear R33 brakes painted in gold -------------------- Skyline GTR Twin Turbo - Garrett turbocharger equivalent models
Garrett 2860R-7's 0.42a/r (60.0mm) compressor 0.64a/r rear (HKS GT-SS equiv) = 300 to 330rwkw range Garrett 2860R-9's 0.42a/r (59.4mm) compressor 0.64a/r rear (HKS GT-SS equiv) = 300 to 330rwkw range Garrett 2860R-5's 0.60a/r compressor 0.64a/r rear (HKS 2530 Equiv) = 360 to 420rwkw range Garrett 2871R-10's 0.60a/r compressor 0.64a/r rear (HKS GT-RS Equiv) = 440rwkw to 500rwkw -> Apexi PowerFC FAQ has been updated (May 2009) - ChangeLog |
paulr33 Painting Your Brake Calipers 4 Dec 2005, 05:27 PM
Bobjones Nice work!!!
Good inclusion re the re... 5 Dec 2005, 12:28 PM
SLIPPERY VL you can also scratch off the paint on the nissan l... 5 Dec 2005, 01:15 PM
nathn_r33 I put baby bum cream very lightly over the word ni... 5 Dec 2005, 03:57 PM
Eug QUOTE(nathn_r33 @ 5 Dec 2005, 03:57 PM)I put ... 6 Dec 2005, 07:32 AM
OzanMakinaci You guys have any preference as to what type of pa... 26 Jun 2006, 03:29 PM
MacGuyver I've used a paint called 'Metal Cast' ... 26 Jun 2006, 05:33 PM
snake So you dont make the same mistake i did, i went to... 26 Jun 2006, 11:52 PM
Bass Junky You should also prep the caliper to be sprayed wit... 27 Jun 2006, 10:16 AM
dezz someone once told me that you dont need VHT paint ... 28 Jun 2006, 12:33 AM
Flash89 what happen to the pics?? 6 Sep 2006, 02:41 AM
heslo Awesome tutorial, just did this today when I repla... 22 Sep 2006, 10:36 PM
kursed can these pics be resurected I want to see them be... 8 Oct 2006, 07:43 PM
CATKICKER Hope this helps.
I did mine this weekend. Pretty ... 8 Oct 2006, 08:48 PM
dezz you in melbourne todd? I'll give you a slab to... 8 Oct 2006, 08:53 PM
CATKICKER Sorry mate, not in VIC. Wouldn't do it for a s... 8 Oct 2006, 09:05 PM
dezz hehe its cool
did you just use masking tape on t... 8 Oct 2006, 09:10 PM
CATKICKER yeah, a combination between the thin and thick stu... 8 Oct 2006, 09:42 PM
dezz yeah thats how i did it on my TX5 back in the day.... 8 Oct 2006, 09:46 PM
d00dz Can I ask, the otherside of the caliper, it is spr... 13 Oct 2006, 03:28 PM
blinko yeh i did mine the other week.. they look good... ... 30 Apr 2007, 09:29 PM
Bass Junky You don't need too. I did becuase I took my c... 13 Oct 2006, 03:41 PM
Flash89 so was the whole caliper painted or just most of t... 22 Oct 2006, 02:27 AM
MacGuyver That looks awesome Catkicker, what sort of paint w... 1 Nov 2006, 03:51 PM
cowie165 Another excellent caliper painting thread here:
h... 1 Nov 2006, 07:18 PM
Beer Baron good guide, but my main suggestion would be do not... 1 Nov 2006, 11:17 PM
d00dz QUOTE(Beer Baron @ 2 Nov 2006, 12:17 AM) ... 2 Nov 2006, 06:56 AM
Eug QUOTE(d00dz @ 2 Nov 2006, 06:56 AM) How w... 2 Nov 2006, 09:38 AM
mteched what took me only 1 hr to paint all 4 calipers lol... 2 Nov 2006, 05:42 PM
Ultimategtr ah yep im thinking of doing my calipers soon lol. ... 22 Jan 2007, 01:01 PM
markimak to remove calipers ther are two 17mm bolts on the ... 24 Jan 2007, 01:35 PM
Bass Junky Better than a die grinder is a piece of wet and dr... 24 Jan 2007, 07:30 PM
Flash89 is there a way you can take the whole caliper off ... 28 Apr 2007, 08:03 PM
Basti its written out two posts up 29 Apr 2007, 01:33 AM
cruzin33 I took my cailipers of to paint, iv painted over t... 30 Apr 2007, 05:00 PM
Bass Junky Yep,
Get yourself some Wet and Dry, quite fine gra... 30 Apr 2007, 05:41 PM
Flash89 well what i meant is taking the caliper complete o... 1 May 2007, 02:09 AM
DECIM8 i just removed wheel .. covered hub in news paper ... 1 May 2007, 10:48 AM
mrgilly QUOTE(DECIM8 @ 1 May 2007, 10:48 AM) i ju... 4 May 2007, 11:53 AM
Trust33 I used a wire brush on a drill.Went right back to ... 1 May 2007, 09:01 PM
Trust33 they b coming just waiting for the time to take th... 3 May 2007, 12:02 AM
cruzin33 Did any one paint the nissan logo on the cailipers... 10 May 2007, 07:41 PM
Trust33 no i haventseen the logo painted white.it whold lo... 20 May 2007, 07:47 PM
MacGuyver I've been meaning to paint my Nissan logos whi... 21 May 2007, 02:47 PM
Trust33 hahaha.it wont take long at all to paint them whit... 22 May 2007, 09:39 PM
silverbulletR33 I think wat he Ment was, Taking them fully off Inc... 25 May 2007, 10:52 PM
MacGuyver Hey I know it's been like ages since I said I ... 24 Oct 2007, 12:47 PM
H@ME They look really good!! i have read this t... 20 Nov 2007, 02:29 PM
vietorious Dark blue on silver 20 Nov 2007, 05:04 PM
Flash89 how did yous do the nissan logo?? 25 Nov 2007, 07:07 PM
sotck4door Does anyone saved the pic on the first page??? 12 Jan 2008, 08:56 PM
cruzin33 I just took my Brake Calipers and rotors of again ... 13 Jan 2008, 03:48 PM
H@ME hey guys i tried doing mine today i have preped th... 19 Jan 2008, 02:30 PM
H@ME heres the pics, it like the paint wasn't thick... 19 Jan 2008, 02:34 PM
E_Lu-SHuN you should of bought MC100 ground coat for it..
y... 20 Jan 2008, 11:15 AM
GTScotT it appears that the colour u choose doesnt cover e... 20 Jan 2008, 11:53 AM
DECIM8 I just wrote a post in anodisation of calipers but... 20 Jan 2008, 02:12 PM
DECIM8 H@ME.. Try spraying it again when the calipers are... 20 Jan 2008, 02:15 PM
H@ME QUOTE(DECIM8 @ 20 Jan 2008, 02:15 PM) H@M... 20 Jan 2008, 03:35 PM
Madaz did you even take the black paint off before apply... 20 Jan 2008, 08:49 PM
DECIM8 That looks absolutely shithouse..
Go out buy a wh... 21 Jan 2008, 12:09 PM
H@ME alright, i will have to give that a go, thanks guy... 21 Jan 2008, 02:13 PM
paulr33 QUOTE(H@ME @ 20 Jan 2008, 04:35 PM) thank... 21 Jan 2008, 09:14 PM
Bass Junky Another good method for getting rid of paint is an... 21 Jan 2008, 09:27 PM
H@ME cheers guys, thanks for the input i will be going ... 22 Jan 2008, 10:24 AM
DECIM8 vht is fine mate i use it without a problem, 22 Jan 2008, 11:45 AM
H@ME QUOTE(DECIM8 @ 22 Jan 2008, 11:45 AM) vht... 22 Jan 2008, 12:21 PM
DECIM8 Yes Clear gloss it.. makes it easy to clean and ma... 22 Jan 2008, 01:14 PM
H@ME cheers man i will do that, i will also be doing my... 22 Jan 2008, 01:19 PM
DECIM8 LOL righto .. Well Enjoy that.. Mission to remove ... 22 Jan 2008, 02:09 PM
Fanta R33GTR So, I decided a few weeks ago to paint my brembo b... 17 Feb 2008, 10:03 PM
NA_Goodness That is really cool. Where did u get the BREMBO s... 17 Feb 2008, 11:01 PM
Madaz yeah i went with a VHT gold for mine forgot to do ... 18 Feb 2008, 05:40 AM
H@ME hell yeah tha looks sweet as! mine ended up pr... 18 Feb 2008, 09:10 AM
Trust33 that came up good. 21 Feb 2008, 08:06 PM
Madaz well heres a few pics of mine as mentioned earlier... 23 Feb 2008, 04:08 PM
chrissyo some good results guys
Im looking at doing mine ... 10 May 2008, 12:20 PM
raps86 hey im just about 2 under take this on my car. i h... 26 Jun 2008, 10:59 PM
cowie165 QUOTE(raps86 @ 26 Jun 2008, 10:59 PM) hey... 27 Jun 2008, 11:19 AM
fredman I did this today with red paint as my calipers whe... 5 Jul 2008, 01:25 PM
viet_boi heres mine, did it couple days ago, only pic i too... 11 Oct 2008, 03:06 PM
Bass Junky VietBoy...
What front bar is that? 13 Oct 2008, 07:54 AM
viet_boi QUOTE(Bass Junky @ 13 Oct 2008, 07:54 AM)... 22 Oct 2008, 12:02 AM
NA_Goodness John, that looks sweet!! Gotta come out o... 19 Oct 2008, 10:15 PM
dezz Had mine powdercoated in black and the lettering s... 20 Oct 2008, 12:53 PM
Oo oO ive dun my rears in red yeww matches the car lol
c... 21 Oct 2008, 03:43 PM
gotRICE? Anyone know the Regulations on shipping spray pain... 26 Oct 2008, 01:53 PM
GTRsean Painted mine a while back and touched em up when I... 26 Oct 2008, 02:42 PM
cobrAA I bought a Dupli-Color Caliper Kit in RED and I wa... 23 Mar 2009, 10:06 AM
Mr GTS4 no don't use a clear coat.. i found a video on... 23 Mar 2009, 04:35 PM
cobrAA QUOTE (Mr GTS4 @ 23 Mar 2009, 04:35 PM) n... 28 Mar 2009, 01:37 PM
AUS R32 Im a new member and was looking for ways to spruce... 26 Mar 2009, 04:56 PM
Mr GTS4 you could use a metal file maybe.. just be really ... 30 Mar 2009, 03:09 PM
Craved 6" DA sander if you have one is perfect for s... 3 Apr 2009, 10:50 PM
TALBO For those of you who used Duplicolour Metacast on ... 5 Apr 2009, 09:28 PM
SLY-25T i just finished doing mine today. sprayed on the c... 6 Apr 2009, 04:43 PM
TALBO QUOTE (SLY-25T @ 6 Apr 2009, 05:13 P... 6 Apr 2009, 05:21 PM
SLY-25T ill get some pics for ya 2moro steve. 6 Apr 2009, 07:16 PM
TALBO Thanks 6 Apr 2009, 07:25 PM
SLY-25T steve-
7 Apr 2009, 07:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 11th March, 2010 - 04:41 PM |
