My Power Steerings Gone After Installing Hicas Lock Bar
A is the HICAS CU. As far as I know, there are no other modules located at A in a car with HICAS, so it is fair to presume that F is the variable power steer module for non-HICAS cars. Same location, give or take. Makes sense - the wiring loom for the HICAS cars has the speed signal, power, solenoid drive, etc wires all present there - so why move the module and have to upend the wiring loom? Yes, it is the multi-pin plug next to the under dash fuse box. Top left corner. Can't miss it. Be very careful though - use insulated probes to poke around in there so you don't accidentally short 12v to ground or an ECU input etc etc.
They didn't. This is their comments; I'm not sure why they don't have the OEM specs.
Did the oil analysis include the acceptable range for Lead? Last one i has said 1ppm is the limit and the engine I was testing had 74, 80 and 33 (was the race car, tested from brand new run in engine). It may not help to tell you the engine didn't last long, but they never did back then
My engine has only an oil pressure switch from factory and I've installed an after market sensor that will alert me to pressure loss (https://www.sau.com.au/forums/topic/484431-my-bmw-335i/page/3/) . These engines can definitely feel long left/right handers which is why I added this sensor. There are no other symptoms at all. No strange noises (in fact after the turbos were replaced the mechanic made a note of how sweet the engine was running), no smoke, no glitter in the filter, nada. I'm just a stress head with car issues, I hate there being anything at all wrong with my cars, even if its basic. I just immediately get anxious and start thinking about catastrophic failure.
Do you know where the EPS module will be located? And also the diagnostic connect located under the dash?
