IPB
20 Pages V   1 2 3 > »
> How to turbo your N/A
666DAN
post 2 Feb 2004, 05:38 PM
Post #1
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
So you want to get more bang for your buck and whack a turbo on your skyline….well the following are things I’ve found out on this ever talked about path.
First thing…get yourself an N/A Skyline, if you’re reading this then you too have made this fatal mistake wink.gif
The second thing you should do is get yourself some sort of engine management…one that can adjust airflow maps and injection maps…to a lesser extent timing.
I used the GReddy e-manage as my car is auto and I didn’t have a choice in the matter, even if it had been manual I still think I would have got it, due to the ease of installation and programming.
Other options available are getting the factory ECU…but I’m not sure if it would work as it would not have all the signals coming in that the stock turbo engine would put out.
Next step get the essential engine parts…you WILL need the following.
Turbo (of course) preferably with water an oil lines
Exhaust manifold
Dump-pipe & Front pipe
Fuel Pump (GTS-t one or better, plenty of high-flowing cheap ones out there, walbro etc)
Injectors (stock GTS-t ones or better)
Intercooler and piping (stock or custom)
Alloy cross-pipe with BOV (once again custom jobby will suffice)
All of the above can be the factory items or replacement parts for the turbo model, not a bad idea in the case of the intercooler…as with your 10:1 compression keeping things from going boom is a good idea smile.gif
I used a series 1 R33 turbo, ceramic exhaust wheel jobby…you don’t really need anything more substantial as you can’t go too far past 7psi and the ceramic turbo should last indefinitely at this boost.
Almost all of these items went straight into my R34 with only the exhaust requiring an extra section welded in to make it fit.
The oil & water lines were modified and extended with stainless steel braided hose. The water supply was taken from the heater lines…the oil feed had to be taken from near the filter and the return is via a tap into the block..
Standard, the waste gate on the turbo will open at around 5psi..to get 7psi you’ll require either a bleed valve…or the factory solenoid powered by a constant 12v and put inline with the actuator hose on the turbo.
So now you’ve got everything bolted to your engine you need to get a complete dyno tune, where your ignition will most likely be retarded by about 5 degrees just to keep things safe. Once completed you now got a very different car from when you began…it’s actually got some decent power biggrin.gif
Of course none of this would have been possible without Robin at *perFOURmance Motorsports*
The final tune on my car is Thursday, so I’ll have dyno charts and pictures available on Friday.
Anyone wanting specifics PM for more details.
So let’s see who’s next!
Dan
My LED dash kits are available through SAU and Zero Point Electronics feel free to contact me via the link for kits!
Find turning your TCS off annoying? Here's the fix, defaults the TCS to 'OFF' - R34 TCS Cancelling Circuits $40 + postage Click Here
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Genesis®
post 2 Feb 2004, 06:43 PM
Post #2
Old Skool
Car(s): R34 GT Sedan
Real Name: Glenn
Trader Rating : 7
Dan, can you do a rough price breakdown guide as well?
:: Foot to Metal :: Full On :: All of It or None of It ::
Profile CardPM
+Quote Post
666DAN
post 2 Feb 2004, 06:46 PM
Post #3
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
Parts would be available for under $1000...maybe cheaper if you can hit up your mates for there old bits
The e-manage you're looking at $750
Installation...including unforseen hassles and some forseen ones too $1300
Dyno tune $200
So definately have $3000 ready.....but you may suprise yourself that it doesn't cost that much smile.gif
My one was a bit of a special case, seeing as I was throwing R33 bits into an R34...some fit some don't
Profile CardPM
+Quote Post
MirKz
post 3 Feb 2004, 01:49 PM
Post #4
Trader Rating : 0
havent you forgotten to list pistons ?
you need low compression pistons, otherwise using the standard high compression pistons that NA's have will just F*&k ure engine VERY quickly.. although i have heard u CAN run a turbo, low boost (such as 7psi max) and still get a very quick car outta it without changin pistons.
SAUWA Member #8
Profile CardPM
+Quote Post
666DAN
post 3 Feb 2004, 05:18 PM
Post #5
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
MirKz: that's exactly what I'm doing I'm running 10:1 compression with low boost...Saab style, gives good results, without killing bits.
Squizz and Crooser did a similar thing to there R33's
Profile CardPM
+Quote Post
Demon Dave
post 3 Feb 2004, 08:08 PM
Post #6
On The Far Side...
Car(s): BNR34
Real Name: Dave
Trader Rating : 0
This is a great thread. some very useful info and it would be cool to have a step-by-step guide to turbo'ing an N/A. Some questions though:
Since your running 10:1 on the compression and using quite a low boost setting what kind of performance gains are you likely to get? Approx?
Even at the low boost levels, are there gonna be any long term reliability issues?
Given the costs involved, is it easier/cheaper to do a turbo conversion, or do a complete swap (RB25DE to RB25DET) and then sell the old engine?
Thanks
Dave
GTROC UK / Oo Skyline oO
Skyworks
Profile CardPM
+Quote Post
666DAN
post 4 Feb 2004, 07:46 AM
Post #7
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
For guys who own R32s and R33s then the engine swap is probably the best way, but getting a cheap R34 Neo RB25DET...and getting it swapped is not a cheap option at all.
As for reliability...I've heard good things from people...and for the realatively low cost of doing it, it's well worth the risk and I'm quite happy to be the Guinea pig on this one biggrin.gif
Dave: as for performance I'd say at least 50% let's just say it's definately noticable. Using the e-manage and getting it tuned properly will also add to reliability. I'll have power figures and A/F ratios for you guys tomorrow afternoon.
Dan
Profile CardPM
+Quote Post
Pva_Glue
post 4 Feb 2004, 11:14 PM
Post #8
Yellow Fever
Trader Rating : 4
Dyno sheet b4 and after???
Profile CardPM
+Quote Post
cul202
post 5 Feb 2004, 08:04 AM
Post #9
Beer > Food
Car(s): HCR32
Trader Rating : 5
it would make for a good street motor - strong top end of a turbo motor with low end punch of a NA motor with high compression. oh and VVT as well
wanna swap with my rb20det when your done tuning... heheh
Ex red motor owner & proud supporter of the Elephants Head, Camdentown
Profile CardPM
+Quote Post
666DAN
post 5 Feb 2004, 05:32 PM
Post #10
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
OK looks like the dyno run on Saturday is out of the queswtion...I'll come along though to see whos' who though.
Todays events were like this: Engine showed good performance until 3500rpm where it started to miss-fire...all indications are on the sparkplugs which have got a nasty heat rating of 5.....not good for this application. I've now got some with a rating of 7 which I'll put in over the weekend...meaning the car can't be tuned for another couple of weeks *sigh*
Another thing that cropped up today....I was getting 147 rwkws at ~3000rpm...so for good measure the old fuel pump has been replaced with a 550hp item....for those who can do the maths, this is a pretty respectable figure for 6.5psi!!! I'm greatly anticipatng the final figure now.
So I'm afraid due to funds drying up this week...I've been put in a holding pattern for 2 weeks.
Dan
Profile CardPM
+Quote Post
RB32DETT VL
post 9 Feb 2004, 07:59 AM
Post #11
Rank: RB20DE
Car(s): VL Commodore
Trader Rating : 2
G'day Dan
Excellent work man, sounds like it'll be a ripper of an engine. I'm slowly getting the parts together to do an NA twincam conversion (RB25/30) to my VL. I'd really like to build an awesome NA motor, but after a certain point, it's just going to cost too much money for the relative gains. I have the intention of going turbo in the future, but am dreading losing some of the the bottom end, so your build is fairly relevant to what I want to do.
Like the others said, post up some dyno results and boast a bit. Well done.
Cheers, John.
Profile CardPM
+Quote Post
Cecam
post 9 Feb 2004, 01:10 PM
Post #12
Trader Rating : 0
666Dan, how much boost was the turbo making from off idle?
I've worked on a few RB25DE's which have had RB20 turbos fitted to them and they were practically making boost when idling. Massive torque down low but runs out of top end very quick... One of those cars now runs a fairly insane turbo/setup (still high C/R for response), makes about 300 rwkw or so, that was done nearly two years ago and its still going, really needs good tuning to keep them together....
Profile CardPM
+Quote Post
666DAN
post 9 Feb 2004, 06:48 PM
Post #13
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
Cecam: good to hear that you've seen these things working...everyone I've spoken too just dismisses it as a stupid idea...doesn't seem like one from where I'm sitting though biggrin.gif
I don't actually have a boost gauge on the thing, but yeah it boosts very quickly...sounds like I've got an electric leaf-blower on the engine it's either full or nothing smile.gif
Tuning is still a must...I'm chugging fuel badly at the moment...just waiting for the cash to get it done as I had some very unsuspected costs appear!
The second I get some results I won't hesitate to put them up.
Dan
Profile CardPM
+Quote Post
hea69d
post 5 Aug 2004, 06:25 PM
Post #14
Rank: RB20DE
Trader Rating : 0
from reading all this is does sound worthwhile. was the list at the start pretty much all you need as i'm not too mechanically minded so i'l be handing it to my mate who is a mechanic and we can go from there. really appreciate sharing the info however smile.gif
Profile CardPM
+Quote Post
666DAN
post 5 Aug 2004, 06:58 PM
Post #15
L-Plate DJ
Group Icon
Real Name: Dan
Trader Rating : 102
6 months later and my ignition timing still hasn't been sorted biggrin.gif this weekend the computer is getting played with some more to squeeze those extra Kws.
hea69d...you'll need a fuel pump too, mentioned that further down the list...and timing control too sad.gif
Profile CardPM
+Quote Post
