Xenon Hid Lights Conversion For R32
Ronin 09
Started my retrofit today. Morimoto FX-R projectors are almost the same as R32 projectors. Tapped one corner and drilled the other, went straight onto the adjusters. Tap: 5mm dia 0.8mm pitch (M5x0.8). Need AMP to D2S straight adaptors, which I didn't order beforehand so my retrofit is on a hold :(.
So finished up at 3am lol started at 11:30pm
Standard R32 - Morimoto FX-R
Tap this existing hole with M5x0.8mm
Drill then tap the bottom right hole
What you end up with
As you can see, the FX-R is a bit shorter than standard. You can make up a mounting plate to offset the difference, but the gap doesn't bother me.
4300K cheap bulb and cheap LED parker. Note the parker is more than 6000K i.e. blue
Need to adjust it a bit more. The hole you drill will determine the angle of the beam as well. When I do another set I'll put more effort into where to drill the hole.
Crap picture, but they are so much more better than standard R32 projectors, as expected. Can actually see the road.
I'm going to put the fault with the bulbs for the uneven spread. High beam is awesome.
I've kept the standard halogen high beam so I can flash during the day. But when the shield drops, you can barely see the halogen. They are 85W, which I'm assuming is factory as both my projectors has them.
Edited by niZmO_Man
images rehosted
Here is a crappy pic of the second set I did. Painted the cover thing to make it look like R31 style :P
On 25/03/2013 at 11:17 AM, BWRGTR said:
awesome work, do u know if there are any options with N1 headlights, i believe it uses reflector rather than projector?
perhaps fog lamp in headlight can be done as a projector
Get a pair of projector headlights and sell your N1s (they are more valuable). You can retrofit the Morimoto Mini H1 (or D2S) into reflectors, but pointless really.
  • 2 months later...
I will be doing this to my R32 headlights when I get the chance (when I get off my ass)
Does retrofitting these HID projectors onto the headlights make them LEGAL and still retain the self-cleaning/adjusting mechanism?
They don't have self leveling, hence the cheap price. If you want OEM spec, be prepared to pay $1k+ for used headlights + parts. You will then have to put the squirters on your bumper (self cleaning). Self leveling is built into the projectors so it shouldn't be too hard to wire up.
^ I guess if they are smart enough to realise that it isn't stock. Some r32s had OEM projectors and others just non-projector types. You could feign ignorance saying it was stock OEM projectors but upgraded bulbs.
But seriously I have the stock crappy non-projector type - and nowadays I reckon I'm the odd one out coz I'm surrounded by projector types...
Yep. You can fit all the auto leveling and squirters, then have it engineered and they can still defect you.
But you're better off doing a retro with a Morimoto projector and 4300K bulb. Just aim them properly. Much better and far less glare than putting HID kit into a halogen headlight.
If you put anything higher than 5000K you deserve to get defected. Same goes with higher wattage. 35W is plenty, if you need more and you're driving around town, you need new glasses or stick to daytime driving.
Remember ALL OEM HIDs are 35W and have 4200-4300 K bulbs (unless you have a Merc, I believe the S class comes with 5000 K Osram bulbs).
I've seen far more projector headlights than reflector ones on an R32, so you have an uncommon/rare car ;). Put some Blue plus 90 bulbs in, or grab a pair of projectors and retrofit them ;)
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
