Xenon Hid Lights Conversion For R32
Ronin 09
Some points to note after reading some of the recent comments:
1. "Self Levelling" is NOT "built" into R32 halogen projector headlights. A vehicle will have "Self Levelling" (aka: Auto Levelling) if the particular headlight had a levelling motor attached to the back with a plug coming off it that was connected to sensors on the front and rear suspension of the car. These sensors measure suspension travel in conditions like:
* acceleration
* braking
* incline surfaces (up hill)
* decline surfaces (down hill)
* vehicle speed
This information is sent to a control box unit or the cars ECU (manufacturer specific) then relayed back to the motor on the back of the headlight to make adjustments.
Back when Nissan made R32's, Japan's HID lighting regulations didn't require vehicles to have
* Auto Levelling &
* Headlight washers
Not sure if Japan has toughened up its HID lighting regulations like Europe / Australia etc..
^^ having said the above, I'm willing to bet R32's DO NOT have auto levelling headlights. It's not as simple as retrofitting the auto levelling wiring and sensors. Where the hell are you going to get these from and how are you going to fit them to the car??
2. Of all the projectors mentioned, here are the Pro's and Con's
* Mini H1 6.0
* Honda Euro (aka TSX)
* 3" FX-R 3.0
Mini H1 Pros:
* Smallest of the 3 projectors. Plenty of room for fittment
* Projector also has high beam function. Can be wired up with OEM high beam to give a quad high beam output
* Readily available projector. TheRetrofofitSource own the production rights to this projector.
Mini H1 Cons:
* It's considered an. "entry level" projector. Light performance is last compared to the FX-R and TSX. Still 10 times better than the OEM projector
* Mini H1 uses a 2.5" lense. OEM lense = 3". The small gap around the projector may / may not annoy you. Better than the TSX gap
Euro (TSX) Pros:
* Wide beam pattern looks awesome. When mated with a TSX-R clear lense it produces an awesome blue "colour band" than the FX-R and Mini H1 can't match.
* Medium sized projector that has more fittment room than the FX-R
Euro (TSX) Cons:
* Not an easily projector to find in RHD format. You need to know where to look ;P
* To get that blue "colour band" you have to purchase a TSX-R clear lense. More money ontop
* It's a low beam only projector. No high beam function means it falls behind the Mini H1 & FX-R
* Uses a 2.5" lense which will result in a small gap around the projector. Worse than the Mini H1
3" FX-R Pros:
* Uses a 3" size lense just like OEM. No gaps
* Wide beam pattern,, Already comes with a clear lense do nice & sharp out of the box (just like the Mini H1)
* Also has high beam function
* Readily available from TheRetrofofitSource, who also have the production rights to this projector
3" FX-R Cons:
* The biggest of all 3 projectors. Less room toake adjustments
Projector bulb types:
* Mini H1 = HID H1 bulb
* Euro ( TSX) = D2S bulb
* 3" FX-R = D2S bulb
If you get defected then you can convert back to halogen:
* Mini H1 = halogen H1 bulb
* Euro (TSX) = halogen H1 bulb with metal convertion washers from compliance workshops
* 3" FX-R = halogen H1 bulb with metal convertion washers from compliance workshops
  • Like 2
That was my point. If you want the auto-levelling function, good luck. Only way is to maybe find a wreck and hope everything works.
FX-R is a big unit, but it goes into R32 housing with minimal fuss. I bought three! lol
I also have H1 Mini and D2S Mini. I think the FX-R will struggle to fit into R31 projector.
  • 1 month later...
  • 3 weeks later...
Guys, just wanted to throw this HID kit out there:
http://www.ebay.com.au/itm/280831816424?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Bought it for less than $35 delivered!
I've had them installed in my car for just over a week now and they've been great. They're a direct fit (H3C) into an R32 GTST, not sure about others. Highly recommend this kit for the money though!
I just threw out "Hyluxtek" ballast #2 which blew up. My car has relays so it's not like it's getting clean voltage. The kit was ~$150.
That $35 kit won't last. I know, I threw two pairs of their kind in the bin after 1-2 months of service.
Also, since you have R32 projectors, you must be loving the pencil beam :P
  • 7 months later...
+1
I bought an $80 kit a few years ago, then later on bought a near $200 kit from the states and while the first kit hasn't failed or given me any issues, it is nowhere near as good as the more expensive kit. It's a fairly massive difference between the two. The expensive kit heats up to full light output in about 1/10th of the time of the cheap kit. Seen as the cheap kit is on my low beams I don't care so much but if it ever fails I'll replace it with the same kit as I have in the high beams
I can see things now!
A lot of pain and suffering but in the end it's worth it when everything shines bright.
Used Morimoto Mini H1 6.0 kit into R32 GTR projector headlights
If you think Mini H1's are good... You'll be blown away with:
* RX330 non-AFS projectors with E30 clear lenses / Osram 66240 D2S Nightbreaker's / OEM Denso slim ballasts
or
* RX350 BiXenon projectors with STi-R clear lenses / Osram 66240 D2S Nightbreaker's / OEM Denso slim ballasts
^^ that's what you call high performance lighting
or
Compared to what my stock R32 projectors were putting out, the Minis are amazing.
If they blow up I might consider RX350 projectors.
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
