13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Admin delete if not allowed please, I just purchased an r32 GTST with a Gtr front bar , grill I assume bonnet? (maybe) I have 2 questions he told me it had an RB25det I’m new to the RB world, and this is the photo I have taken and also I noticed a piece near my suspension broken is this fixable , will update new photos tomorrow once I have lifted her up and removed the LHS wheel I want to know if there is ways around this , I didn’t notice anything as it drove with no knocks on the suspension or weird feeling the car feels sluggish, and the rpm cluster literally goes to 3.5-4k rpm and when you put your foot down it dances around like the local girl on Canterbury road or Sefton playhouse the car sat for 8 years he said the oil was dropped and re done , I noticed the oil was very clean car starts no problems by all means it’s not a clean car it is a project but doesn’t need much, knowing me I will go overboard the colour is horrible car has 88k kms hardly driven needs a few things but it’ll be fun to build properly so guys is this an rb20 or rb25 and what is this bracket called? Can it be fixed thanks
found this on the forum , suggests I am in the range ----------------------------- From the segmented (potentially incorrect) information I've found that; Early R32: RB26000XXXX to RB26002XXXX Mid R32: RB26003XXXX (V-Spec I RB26-03XXXXX - Reference Classic Register) Late R32: RB26004XXXX (V-Spec II RB26-042XXXX - RB26-045XXXX - Reference Classic Register) Early R33: RB26005XXXX Mid R33: RB26006XXXX (as per the engine in this R32 V-Spec II, which is what I'm concerned about from legitimacy perspective) Late R33: RB26007XXXX Early R34 (2000+): RB26008XXXX ----------------------
Now as I understand it the engine numbers are sequential for the rb26. EG stamped - RB26040100A is a 40,100 engine. Now they made between 1988 and 1994 43,834 R32 GTR's In 1994 they made 7,464 r32 gtr's. So if you have a ~37,000++ number RB26 it's "safe" ish to assume its an 1994 motor and a long nose crank ? The long nose crank being introduced somewhere in Feb of 1993.
By dawhitehonky · Posted
Try Christian from ITSROM. He should be able to help with a modified ECU. Itsrom | Facebook or you can send him an email on itsrom AT outlook.com
