convert tractive effort to torque
OK boys and girls - I have a math quiz for you all
I have just had a power run done on my R32 GTR and have a reading for tractive effort, and I want to convert that to an approximate torque figure (Nm)
from the following web site
http://www.webster-inst.com/techinfo/equat...eqnfr/eqn17.htm
we see that the tractive effort is obtained by multiplying the torque by the total ratio of power the train and dividing this sum by the rolling radius of the driving tyres. (easy)
TE = (T * R * 1000) / r
where
T= Motor torque in kg/millimetres (the number I wish to calculate)
R = Overall gear reduction including both axle and transmission (NFI)
r = Rolling radius of loaded driving tyre in millimetres (measure)
So in my example, I have a measured TE of 6300 newtons – based on the output of the power run on a 4 wheel dyno.
BUT
I do not know R or r
Any idea what the overall gear reduction is in an R32 GTR in 4th gear.
Any idea how a can obtain an accurate measure of the rolling radius of my wheel. I have 235/45/17s (with a tape measure I get 2070mm ?)
come on guys – I'm sure this must have been covered before
4th gear is 1:1, and the diff is 4.11:1 (i believe) so R = 4.11?
But using that formula and your figures ends up with 3173Nm! :headspin:
found another formula
T = (9.545 * Power in watts) / RPM
so I get
T = ( 9.545 * (291.7awkw * 1000) / 6500RPM = 428Nm
A more realistic result - but I still have ZERO idea is this is even in the ball park.
A std GenIII V8 reports 475Nm with 255kw and the New Gen4 GTO reports 530Nm with 297kw (these will be @ the engine numbers tho )
I think r = the way you have measured it ie half the diameter. that would make sense.
As for gear reduction, as far as I know it's not just final drive ie 4.11 as you have to take the effect of the gearbox ratio into account. What I'm not sure of is the way you combine these - presumably by dividing or multiplying - although a google search might help. Or just ring a uni engineering faculty and ask, that sometimes works.
I think the second formula looks like it might be OK, they're torquey little suckers.
Good luck
Regards
oops RADIUS not Diameter (bugger)
the RADIUS of my wheel is only 315mm
so I now get
6300 = ( T * 4.111 * 1000) / 315 ) = 482.72Nm
that seems reasonable to me - based on seat of the pants experiance
Actually that 3000 odd figure is Newton Millimetres so thats even stonger! :confused:
We have taken in to account the gearbox, he said 4th gear, and that's 1:1, 1 engine revolution = 1 tail shaft revolution. So we can ignore it.
The problems in the radius bit i think too.
so I now get
There we go! :cheers:
Wouldn't it be easier to convert your horsepower to torque using the rpm?  :confused:
You can do it this way, but i wouldn't use horsepower, i'd stay in metric units to make it easier.
Torque is also a power multiplied by an angular velocity, so if you look on a dyno graph the power should be simply the torque multiplied by the rpm times some conversion factor based on the gear the car is in and the radius of the cars wheels.
... the rolling radius of my wheel. I have 235/45/17s (with a tape measure I get 2070mm ?)
That's the rolling CIRCUMFERENCE! Rolling radius will be:
(17* 25.4 + 235 * .45 * 2) /2
(approx 321 mm)
ok what the conversion for ftlb to newtons
as mine made 410ft/lb on 275/35/18 at about 6500rpm is high torque point and hold around 400 for about 2000rpm. And made 529.4rwhp
R=324.85mm
6500 = ( T * 4.111 * 1000) / 324.85 ) = 513.6Nm
does this sound right
pete
