R33: Suspension - Fitting Pineapples
Lazy-Bastard
Available all over the place in kits, but I discovered Fulcrum sell them separately so went out and grabbed some.
Large ones (80mm OD) for $17.56ea
Small ones (69.5mm OD) for $14.10ea
I just got the 4, but I suppose if I ever wanted to change the setup i could just go back and get another 2 small ones.
Their small ones don't come with a cut in them, so you may need to cut them if you want easier fitment for either a drift or drag setup.
Depending on how you want to set the rear cradle you only need to buy 4 pineapples. I have set mine in the standard position and only required 2 large and 2 small pineapples. If you want either a drift or drag setup you would need 4 small pineapples.
Total cost was under $65.
Fitting is simple and takes approx 45 - 60mins.
Tools required:
-17mm socket and breaker bar
-14mm socket
-trolley jack
-ramps make life easier
Photos below, as well as a link to the whiteline fitting instructions. They are pretty self explanatory, so once you have a read, look at the photos, and then have a look under your car it should be obvious what needs to go where etc.
I just backed my car up onto some car ramps (remembering to chock the front wheels), then did one side at a time, while supporting the subframe with a trolley jack (it didn't really seem to need supporting but that is what is stated in the instructions).
The Whiteline instructions only mention removing 2 nuts either side (one at the front and one at the back), but I removed an additional 2 at the front from the subframe mounting bracket (marked in the photos) to make getting the front pineapples on easier.
On the front I had to use the jack once I had fitted the pineapple to compress the subframe up enough to get the nut back on with a decent amount of thread, but once it was on it tightens easily.
The rear nuts are a bit hard to get at with a socket/ratchet due to the HICAS tie-rods sitting directly under the nut, so depending on the length/chunkiness of the socket and ratchet/breaker bar you are using, you may need a 17mm spanner as well.
Torque wise, I just tightened everything until I couldn't tighten it anymore (within reason). The nuts were pretty hard to break at first when removing them so I'd say you are pretty right to tighten like a bastard.
If anyone can see anything I have done wrong or would care to elaborate on anything, feel free :)
Whiteline fitting instructions:
http://www.whiteline.com.au/docs/instructs...203a_KCA349.pdf
Front mounting position. Just underneath in front of the rear wheels:
Rear:
I think there is an all-round improvement in the rear end. Acceleration feels like it has improved and possibly braking also. There is less squatting and pitching when getting on and off the brake and accelerator.
When cornering there seems to be less rear end movement side to side as well, so overall I reckon for the price, they have made a marked difference/improvement.
I got mine from the nissansilvia forums for $60 or so.
The guy there was selling them as a trader so he had heeps.
They're going in this week (read my story here)
I'm going to ask them to be put in on the neutral setting. I figure my car slides happily at the moment so going any more to drift setting would be suicide (or track use only) and the squat setting would be ok for drag but that's not what my car is for.
Has anyone had it on the neutral setting or drift or drag and care to comment on the difference?
  • 1 year later...
Lazy-Bastard you were saying that you need 4 small pineapples for a drift/drag setup, where exactly do the two extra small ones go as i cant see them on the whiteline instructions page
Whichever way you set it up, you only need 4 in total. I think from memory the drift setup requires 4 small and no large but check the whiteline fitting guide
just took a closer look at the diagram from whiteline, i didnt notice the there are small rings and small cut rings, so yes i need to 2 large and 2 small cut for a drift setup. thanks for the info
if they look like this then you need to remove the factory bushes.
If they look like this then you leave the factory bushes in place.
The alloy subframe bushes ARE to be used with the standard subframe bushes. They squash them down and prevent all movement of the rear subframe. The only bushes that require you to remove the original bush are replacement aftermarket bushes, i.e. Noltec
Pineapples are not actually replacement bushes, they are there to help tilt the subframe and resist movement.
And the smaller bottom bush does not require a cut in it at all, you take the nut all the way off, the other 2 at the other end will hold the subframe fine, just loosen them a little first.
Edited by salad
    • Ive heard of OCD works. Hows the spool noise before and after? Feel free to PM links or videos if you want.   I've got a good mate that works for a reputable turbo company who says to stay away from them as theyve had a few turbos that came back with lots of issues. The other reason for sticking with EFR is that its just a drop in replacement. I was looking at the g45-1500 at cost price, but that would mean new down pipe, new lines, new intake piping etc etc.
    • can someone tell me what type the stock injectors are on a 98 rb25det neo engine? all aftermarket intakes require style /size injector pictured below...I need to know what stock engine has. and if they are compatible, or what mods would have to be done.   style of intake I am looking at  https://www.ebay.com/itm/325396084484?_trkparms=amclksrc%3DITM%26aid%3D1110013%26algo%3DHOMESPLICE.SIMRXI%26ao%3D1%26asc%3D264094%26meid%3D5341792cb2134ae08e62edba0106c479%26pid%3D101196%26rk%3D1%26rkt%3D12%26sd%3D266154719116%26itm%3D325396084484%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DPromotedRVIPbooster%26brand%3DCustom&_trksid=p2332490.c101196.m2219&itmprp=cksum%3A3253960844845341792cb2134ae08e62edba0106c479|enc%3AAQAJAAABICwDxH%2FaslyJlxG5OwCzDVs5U6ncPDDFP4HCfgb8bXFQagmnGWQKp%2F5LAV0adQfbjzLOMM5V9WdEAXvNCLcpgDrzFvXcL7dVf5HawGKZAaaGFBnv4h4bnbRe6OSYvS8sL7PFPrxKj1Ffjdm6cYtU05cBROA0QdRKCNqPtF1hizoeiccNy6dwbcFsfX6syZa5MfzX2aEOofmNIehOqxSmtQvJliZHTgLy2BTDxXv5Zq9atpb1m%2BVtBHabBK8Wn6U2uPOAs71mwVWNmc1t4ZnHatrqKLQC6hCPTC8NW3QzFTCUvLg%2FWU4IZ1IAyPK288DdviqpLaN9sgbF3Ia0z6zXqLkqPyXbN7irzRC0HP2kjwHM8czF9PjWtRHDVNb1AiU9%2FQ%3D%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01HWN3YNH6HQ8PEG4RPPSH1HSB thanks
    • Hi Experts, My father’s car Mahindra Jeep CJ500 2.5L, 1986 model. Currently registered in Overseas.  Want to replace the engine in Overseas with Mahindra Bolero 2016 2.5 L turbo used engine ( not endorsing new engine number on Rego paper in Overseas. Then Importing to NSW. Is this car eligible for NSW registration if able to submit all compliance certificates?   Regars.
    • I know you said no amps in the boot, but there's enough space next to the battery for a pair of modern small foot print amps OR one small 6x channel amp. This is what I did over 6 years ago, used 2x marine amps (no decent 6x or 5x channel amps back then)
    • Pressure delta gauge is pure pron. No guessing, no excuses.
