Roof Racks
Sydneykid
Just what I've been looking for, but didn't want to spend upwards of $200. Did you order through their website?
EDIT: Couldn't find the particular model you specified on the website.
Sorry to dig up an old thread, but I just got a set of roof racks for my Series 2 Stagea and wanted to advise other owners that these fit perfectly;
"Jetbag" brand. Owned and made by Thule (Sweden), 3 yr warr
Model- Complete 6501
Black 126cm long with black foot kit
Lockable
75 Kg rating (very good)
Got them through these guys based in NSW - $105 delivered (less than 1/2 the price of ROLA, THULE and the other major brands).
http://www.roofrackworld.com.au/
More info here.
http://www.jetbag.com/
Apperently the same as the current model Toyota RAV 4 with roof rails.
Edited by webng
Go to www.jetbag.com
then click on "load carriers", then "jetbag complete" then "railing rack".
I ordered these through Roof Rack World in NSW by phone.
Ring them and ask for the above "Jetbag" ones for Nissan Stagea....the guy was very helpful (Daniel I think his name was) and measured up a new RAV4 that he had outside after I gave him some dimensions of the roof rails on the Stagea and said they will fit fine.....and yes they did.
Sometimes they also advertise on Ebay.
The racks are compatible with the full range of Thule accessories as they have the standard size bar.
Fantastic, thanks for that.
  • 10 months later...
  • 4 months later...
Thanks for that, off to the local Auto One store I go......will post pictures when fitted.:)
Another person sorry to dig up an old post but...... just wondering if anyone has pics of their roof racks yet? ;)
QUOTE (Sydneykid @ 13 Jan 2005, 07:21 AM)
Hi Guys,
Has anyone had a look at Repco?
They had two or three brands of roof racks (rola, thule?, .......?) with a multitude of accessories and clamps for different roof rails in their range.
I saw a particular clamp that im sure would fit a stag, both the clamp and bar it
suited was quite aerodynamic.
Pete
  • 1 year later...
AutoBarn catalogue just arrived (13/10/2010) with a set (pair) of Buzz Roof Racks for rail-type roof mountings (like the Stagea).
$89 for the pair.
Just bought a set of these. They fit PERFECTLY! Will post pictures soon. And also plan on buying some bike rails for it too.
Wait whats this, some roof-rack-toting bicycle riding family wagon with a slow-poke behind the wheel? Then BAM!, gone in a cloud of fuel and carbon :no:
are they aerofoil style?
or box section?
might have to investigate further
nah just square tube (slightly rectangular). Repco currently has 50% off Rola racks, but they dont make some for stageas, and even went to a roof rack specialist and he basically said 'well they dont make them, so all i can offer is Thule universal ones for $270 a pair'... :no:
Whats type did you end up getting?
They are the AutoBarn ones I noted above. $89 for the pair, made by Buzz Roof Racks.
Here's more pics, I mounted my bike to the top this morning :blink:
  • 4 months later...
does anyone have any more photos of their roof racks installed? The square type ones would be ok, for a couple of trips now and then, but don't they create a fair bit of drag and noise? just what i've heard.....
still thinking to get a set of rola racks..... just a bit pricey for only being used a couple of times per year... hmmm decisions
    • The stock one will outperform any aftermarket standard position exhaust manifold. If you don't believe me, do a back to back test (same turbo, same boost, same timing) and you'll be super surprised.
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
