ecu options for auto r33
  • Replies 49
From my knowledge... Any ECU will work in an auto 33 Skyline... They just don't change gears properly... The shift from 1 to 2 is HARSH!! And it holds gears too long and it doesn't kick down...
This is definately the case with the Wolf Plugin and more than likely the case with the PowerFC...
I'm in the process of working out which signals need to be brought across to the auto ECU to "help" with this problem... It will never be perfect though, but some gains have been made...
hey im pretty much in the same situation
haave an auto r33
i was wondering with the haltech ecu i think its the e6X
if ya can put that into an auto, i'll find out more info but
yeah at the moment thats what im goin to do with replacin the stock ecu
just got the t04E hybrid turbo
be doin front mount soonish
and will have to find someone who can do a custom manifold for a good price .
Yeh ive done some research into this aswell and found that NO stand alone management works properly with the automatic gearbox. There is no gear logic code (thanks sk) :(
Been in autos with a wolf and powerfc now, wolf was better but still too much for me.
We know that the only way to have control over fuel and timing on the automatics without any change in the gear logic etc is to use piggybacks - most commonly SAFC2+SITC. Ive been told by a few people now that tuning the SITC does not affect the autobox at all, making it the only device i know of able to controll timing properly on an autobox without affecting it.
Obviously this limits tuning capacity and capability,
by only having about 260rwkw (highest ive found on standard ecu with piggybacks) of power available, only +- 50% fuel cotrol and timing control of 5 increments (800, 2400, 4000, 5600 & 7200rpm) with adjustment upto +- 15 degrees.
We know the SAFC2 can work with a Z32AFM in an automatic, well pretty certain anyway :)
And that larger injectors CAN be used by tuning the SAFC2 but its still uncertain how well they will work and what problems will occur when only being about to controll the air/fuel ratios to run the injectors.
Thats bout all i can think of :wassup:
in this thread
http://www.skylinesaustralia.com/forums/sh...t=automatic+ecu
sst in perth seem to claim that the wolf plug in will work perfectly with no splicing on a r33 auto . does anyone have concrete info contrary to this ?
my fav autronic tuner in perth claims he can get an autronic shifting perfectly also . he also is working on a remapable nissan ecu replacement , using a different ecu modified to work in the r33 . Im inclined to belevie him on the autronic as he knows his shit and had some very hardcore s13 autos running them
arkon i have wolf in my auto 33 and steve convienently doesnt say anything about any shifting problems with the auto.......... but my gears hold much longer then they should the kick down didnt work properly and 1-2 gearchange is harsh
i bought this unit under the pretense it did work perfectly with the auto as that what a workshop in perth told me..... hmmmm
Yes I have been going through this for a while I currently have a Wolf3D but I still haven't got it installed as yet just waiting for my intercooler to turn up.
I have tried the Power FC and it was harsh I have tried the wolf but just with steve-sst base map it was harsh but not as harsh as the power FC still needs some tuning.
Now people are saying that there wolf ecu are not working properly with there auto ecu and the gear changers are still harsh, I really didn't want to hear this.
Maybe Auto Skylines are supose to stay stock :( and just look good.......................
When the gearbox changes gears it tells the ecu to drop the timing and/or fuel momentarily so that the power is dropped and the gearbox doesn't suffer on the change.
ECU's like PFC and Wolf don't do this so you will probably eventually blow up your box.
I have a chipped ECU in my R34 tiptronic.
how much of this could be controlled buy tuning the wolf , would some wolf installs be better than others ? or is it a matter of its just not possible because of hardware.
perhaps a manual conversion will come sooner rather than later
i am enjoying the lazyness of the auto though
