Rb25 Turbo Upgrade, All Dyno Results
rb25det neo
ev14s injectors
ebay himount manifold
tial 44mrv gate
garrett anti surge gt3540 with a .63 rear
3 inch turbo back hi flow cat 2 mufflers
hks return flow intercooler
z32 afm
power fc
turbosmart fpr800
walbro 460lph intank pump
374rwkw 19-20psi hitting a fuel restriction at 6800rpm once fixed will see close to 400rwkw pulling hard to redline
R33 GTST S2
stock unopened motor
Hypergear highflow turbo with 0.82 a/r rear housing
FMIC
3' turboback exhaust
Link G3 ECU
S15 450cc fuel injectors
R33 GTR fuel pump
Yellowjacket coilpacks
255rwkw @17psi and requires more decent coilpacks.
R34 GT ... with a RB28DET Neo in it?
Not really sure which thread this belongs in, but it's a RB25 block initially, so we'll go with that.
GTX3076 .082 rear
Turbosmart Hypergate 45MM on the housing
3IN Turbo back exhaust a 5in Cat body, with 2 mufflers and a twin tip end.
Brian Crower 2.9L Stroker kit - Actual displacement is 2.785cc, due to less oversized pistons, so basically just the rods and crank.
Custom JE Pistons for a NEO (comp ratio apparently 8.2:10)
Cometic 1.8mm head gasket
JUN Oil pump
Tomei Type B 260 degree Cams
Metal 3in intake between AFM and the Turbo intake.
There's been some kind of porting/polishing of the exhaust side of the head. Exactly what is unknown..
1400cc Xspurt E85 Injectors
460LPH Fuel pump
Fuel Pressure Regular doing nothing but sitting in the engine bay now
Splitfire Coilpacks
Haltech PS2000
Other funny stuff:
stock exhaust manifold
stock airbox/snorkel
stock intake plenum
automatic transmission (the R34 one) :P
Blitz SE return flow fmic (620x266x76)
Trent actually couldn't go WOT on the dyno until about 4500 RPM, as it was causing the dyno to give big warnings and shut down.
375RWKW @ 28 psi
330RWKW @ 3500 RPM (350 at 4000)
  • Like 2
Don't yell at me I assume if it's a 2.5 head and 2.5 block then it goes here?
Neo head, all com plus ferrea gear, ported, cams
10.5:1 comp
6466 precision 1.00 split pulse housing
Sleeved and grouted block 25 block
2.6 tomei crank
  • Like 5
On my Street (registered for now) R32 GTST tuned 01/07/14
s2 rb25det
osch 14mm 1000cc injectors
Running Caltex e-flex
R35gtr afm
Splitfires
Blitz FMIC
cheap turbo to4e (very old),
Tomei adj EX camgear
Tomei 256 dgr 8.5mm lift IN/EX poncams
42mm alloy rad with big fan with custom folded fan shroud
Aeromotive 340 stealth intank fuel pump
TurboSmart bov
TurboSmart fuel reg
E-boost street bc
Adj HA Tein's
HKS pod kit.
Exedy HD clutch
Has a nice smooth power curve.
Tuned by Steve @ SKR
259.8rwkw @ 16psi
235.1rwkw@ 12psi
First time driving a car over 236rwkw
S2 RB25DET
GT3076r with 21U rear housing
FMIC
3" exhaust and high flow cat
Power FC
Warlbro fuel pump
Nismo 555cc side feeds
Splitfire coilpacks
Eboost street
Greddy copy intake manifold
BP Ultimate fuel
255.4rwkw @ 7300rpm on 18psi
Work and tune done by Jez of DVS Tuning
Edited by FordyR31
Same specs as before, but now has valve springs (head was not removed) and fitted new spitfire coils. Retuned today 762hp @ 2bar :)
R32 Sedan,
RB25NEO (unopened)
Full Race Manifold,
Twin MVR44 Gates
GTX4294R
Plazmaman Plenum
Plasmaman 100mm GTR intercooler
Custom 3" intercooler piping
Custom 4" exhaust
260 degree pon cams
Adjustable intake and exhaust gears (retained VCT)
Arp studs (changed one at a time with head still in place)
Factory valve springs, coilpacks headgasket etc.
Vipec Plug and play for R34
United E85
Allstar garage tune.
681hp @. ~25psiattachicon.gifImageUploadedBySAU Community1393270048.259106.jpgattachicon.gifImageUploadedBySAU Community1393270150.629530.jpg
Edited by Royce
  • Like 2
Spec list as follows:
1994 S1 R33
~165,000 kms, unopened engine
Nistune ECU
GTX3067 w/ 0.82 A/R Garrett internal gate housing
[Note: yes the smaller 3067, not typo of 3076]
Stock manifolds
Pod filter - Alloy pipe intake
Z32 AFM
Splitfire coilpacks
Blitz SE return flow FMIC
Greddy Profec OLED boost controller
Nismo 740cc injectors
Walbro 465 pump
3" Custom stainless exhaust turbo back w/ high flow cat.
HyperGear TD06 SL2 20.5G in T3x 10cm Turbine.
95 model R33 GTST unopened engine
Stock Cams
1000cc injectors
600x300x75mm Front mounted cool
high mount exhaust manifold
40mm external gate plumbed back.
3inch Cat back exhaust
3inch intake pipe
PFC ECU
Final result: 358rwkws . Vs 314rwkws Ebay TD06 Sl2 20G in 10cm before turbo upgrade.
E85 fuel was used in both runs.
Im using a boost tee as my electronic controller from insight motorsport shit it self after a week. The boost is pretty jumpy you can see it in the power curve I actually hate boost tees after seeing the difference.
Edited by Michael's R33
181.xxxkm unopened rb25det neo
Hypergear ATR43ss2 turbo with all braided lines @ 18psi
720cc ev14 injectors
Z32 AFM
Apexi avc-r boost controller
Front mounted intercooler
Yellow jacket splitfires
Bosch 040 fuel pump
Nistune
3" cat back
265rkw
R33 series 2 GTST
-Unopened RB25
-Hypergear SLSS2 turbo
-4inch intake
-Hybrid Performance steampipe manifold
-Custom dump pipe
-HKS 3.5inch silent power exhaust
-100cell Cat
-740cc deatschwerks injectors
-Splitfire coilpacks
-NPC organic clutch
-Plazmaman Intercooler
-Turbosmart 45mm external wastegate
-Adaptronic plug-in ECU
Made 368rwhp on 16psi using caltex 98, however manifold keeps making a massive exhaust leak so I'm going to take it off and check/machine flat and then get it back onto the dyno to run more boost and make this turbo come alive.
No dyno sheets yet until full tune
Edited by KerrodR33
Unopened rb25 neo
Holster hx35 turbo
Chinese manifold
Custom intake manifold
Denso -850cc injectors
Turbonetics 44mm gate
3 inch exhaust
Spitfire coils
Sard fpr
Both 044 an 040
Z32 afm
Power fc
Car makes 304kw atw on 16 pound an 279Kw atw on only 12 pound
