spot the stagea
mcnamg
Saw #@Old Fella driving down Raymond Rd in Springwood this arvo; the family & I were having an icecream for my young blokes 6th birthday.
Mine was parked out front of RMS.
Hey mate! :wave:
Hey mate! :wave:
Was it you Dale, that was parked on the side of the M4 last week having a snooze? :closedeyes: :closedeyes: :closedeyes:
Nah, I spend enough time driving along the M4; no desire to stop & take a closer look. ;)
Adelaide.. about 2pm. silver m35 blacked out tail lights heading towards the bay on anzac highway at morphett road lights and shortly after a white c34 s2 with dolphin grill diagonal road towards marion.
Edited by c34Florry
Just saw a gold m35 at woy woy McDonald's about 11am, and a white m35 going through Point Claire about 10 mins later. Anybody here?
I was in my green forester :)
