Catch Can Leaking Oil
i bought the car recently im asuming it was like that when i got it
i did a oil refill few weeks ago & checked now its still full though im pretty scared about the leak
can running high boost be a factor in this?
Edited by KrazyTurk
sounds pretty scary to me,I've had a catch can on for 7 years not a drop in it and 15 psi daily.
If I was you I would be very worried time to check every thing,good luck hope it's an easy fix.
As in a top up or did you do an oil change. Or did you just add 5L of oil without draining the old oil like some less than competent forum members have done in the past?
dont see how this would matter
iv got the can replaced now
should i do a leakdown or compression test to be sure?
Huh?
He asked if you drained oil before adding oil. That's a fair question seeing as in the past people have overfilled engines by many litres due to their lack of mechanical ability.
So to be clear. Where is the oil on the dipstick?
