10 Tips For Better Motorsport Photography
MaTBoY
Yo!
This might be useful for you guys who attend, or plan on attending more motorsport and car events :) I've put together a list of the Top 10 things that I wish someone told me when I first picked up a camera and headed track side. A lot of whats in there is common sense, but a lot of it so simple it gets overlooked until it's pointed out or you accidently stumble upon the realization!
http://speednation.com.au/10-tips-for-better-motorsport-photos/
If you've got any feedback on the article I'd be happy to hear it (good or bad) I haven't written for a while and I was pretty dusty when I put it together.
Anyway, ENJOY! I hope it helps you :)
How about some technical help for the folk.
Stuff like:
What shutter speed to get a certain type of tracking shot.
What speed to adjust the autofocus response to.
Also may help to post photos that havent been through photochop if the thing is about photography.
Tips 6 & 8 are good.
