Making Turbo Choices For My R32 Gts-T Which Is Best?
Most likely your engine is toast, but also the R32 GTR has different ratios than the GTS4. In 5th it's basically the same, it's mostly 1st through 3rd that change. Stop trying to do WOT pulls before you make the engine entirely unsalvageable. Do a leakdown test and/or borescope the cylinders first. And a boost leak can overspeed a turbo. Make sure the turbo actually functions as intended. -
Red Bull, if you're reading this thread, please sponsor us 🥲 -
By robbo_rb180 · Posted
Just need to find some sponsor dollars and we'd be good to go.
