Stolen R34 Last Seen 930Am Thomastown This Morning Been In Two Hit And Runs Since Stolen!
By
Tmaree_r34,
in Victoria
Finished building and installing my stroked VQ25DET today. Came out to 2.771ltr. Built myself. VQ35 crank and forged rods, remaining parts are modified VQ25DET. Should I start a build thread ? Any Interest ?
