Anyone Used Knight Engines?
NISR32.5
Builds KILLER engines. A lot of V8 guys use him, but he's built quite a few awesome 2J's and subj engines. His reputation for quality is 2nd to none.
I want him to build the 304 in my HQ ute soon.
Don't know if he's related to steve though Ryan?
one of my best mates had a 351 built buy him, we went down to talk to him a few times. good dude , very professional and very open to discussion and requests, he also built my forged boss 5.4 very knowledgeable guy.
Im looking at getting my rb rebuilt by him on my return to Adelaide
