Nsw Epic Part Out
Hi everyone,
I have reluctantly decided to part out the S13 I have been building.
For sale:
My pride and joy, my VH45DE Conversion.
This was in the car for final mockup before being pulled out to paint the shell. I originally bought a whole q45 that had a running engine to make sure I had the perfect base engine.
It can be run as is in NA or Turbo form. I as planning on running NA initially with 250-260rwk with a tune but people have these engines pushing out 400rwkw+ on standard internals with low boost.
This engine can be run with the factory intake manifold but I would finish the additional Porsche Cayanne Turbo Composite intake manifold thats included.
The original throttle body matchs up and works perfectly and the only thing that is required is an adapotr plate that could be 3D printed or water cut. The intake manifold is a great addition that be proven to see 30hp+, has a lower profile and is a good 15kg lighter that the original setup.
This conversion is an absolute gem and everything has been done to make this a drop in affair from the engine mounts, alternator relocation, shifter mount, gearbox machining to the bolt in brake booster that will clear the cylinder head allowing you to mount it closer to the firewall.
This will easily go into and S chassis, Z32 or skyline. Its 99% of the way there it just needs a great car to star in.
$5500
Engine + Drivetrain + ECU + Loom
New timing chains
New oil chain
Changed to metal backed chain guides
New Nissan Headgaskets
ARP Head Studs
Head Skimmed flat, valve guides and seat checked
Heavy Duty upgraded valve springs
256 Degree Custom Camshafts (The engine is seriously undercammed from the factory)
Hydraulic lifter shim kit
Block Oil resitrictor fitted
Porsche Cayanne Turbo lightweight composite Intake manifold
Powdercoated valve covers with 10AN earls fittings
4x Dash 10 AN 90 Degree
4x Dash 10 AN Straight
2m of Dash 10 AN hose
Mazworx Engine Mounts
Mazworx exhaust flanges
Mazworx Gearbox adaptor
Nismo Gearbox Mount
UAS Slave Cylinder
UAS Clutch Pivot Fork
Z1 Motorsports strengthed Z33 Clutch Fork
Custom Billet Fuel Rails
Z32 Flywheel
ARP Flywheel bolts
Competition Clutch Z32 Stage 5 Clutch
Tailshaft input to box
Xcessive Manufacturing conversion shifter bracket
Xcessive Manufacturing VH45 Alternator Relocation Kit
+ Engine Stand
Spares:
Heads
Intake Manifold
Oil pump
Injectors
Various Covers
Coilpacks
Sump + many more items i can't remember
Rocket Bunny Kit S13 with perfect fitment I had just fitted everything up before paint before I decided to part it out: $950
Front Bar
Rear Bar
Sideskirts
Ducktail
East Bear Mirrors S13 $160
2x Precision 39mm Wastegates $220 Each
Stock camber arm to fully adjustable kit featuring a weld in joint bearings: Any S Chassis $25
Caster Arm Kit: Universal $20
For these following kits all thats needed is the threaded rod to make your own hardcore suspension arms that have sperical ends that are easy to find replacements for.
Once you have the threaded rod which can be bought for $10 a piece online the arms just go together like lego. And are just as good quality as Cazman Arms. There is a
write up on NissanRoadRacing with a link to the excat piece you need. Easy!
Toe Arm Kit $85
Traction Arm Kit $85
S14 Subframe With LCA's and all other arms $150
Goodridge brakeline Kit S13 $150
Energy Suspension: For S chassis
Rear Diff Bush Set 7.1118G $25
Rear CAB Set 7.3119G $60
Tie Rod End 9.13103G $2
Sway Bar Link 9.8120G $15
Steering Bush 7.10104G $10
Front Control Arm Bush 7.3114G $15
Alloy Steering Wheel Spacer $20
Earls Fittings all brand new (price per fitting)
9x Dash 10 AN Straight $12
6x Dash 8 AN Straight $10
2x Dash 8 AN 90 Degree $25
13x Dash 6 AN Straight $8
5x Dash 6 AN 90 Degree $20
6x Dash 6 AN adaptor to 5/16 Tube (Used to go straight from AN to OEM fuel hard line) $10
2x Dash 8 AN adaptor to 1/2 Tube $12
14x Dash 8 AN weld on Alloy $5
10x Dash 10 AN weld on Alloy $5
1x Dash 6 AN weld on Steel $5
1x Dash 6 AN to Bosch 044 In $10
1x Dash 8 AN to Bosh 044 Out $10
6m Dash 6 AN Earls Hose $25 permeter
0.5 Dash 8 AN Earls Hose $15
Billet Resuable Fuel Filter with 8AN inlet/outlet $70
Garret GT4294 Turbo $850
- With GCG Vband 3.5inch outlet
- Oil line and AN fitting included
Infiniti Q45 Caliper Upgrade $50
S15 Helical R200 with driveshafts $325
R200 with 5 bolt spread LSD with 4.11 FD to suit S13/180sx 4 bolt subframe $150
Koni Coilover Kit $1250
This is quite a popular setup now given the poor shocks commonly found in aftermarket coilovers with limited adjustment. There are extensive threads detailing everything on NissanRoadRacing.
This cost $1650 but Im asking $1250
2x Koni Shocks 8610-1436 Race
2x Koni Shocks 8041 1208 Sport
Ground Control Coilover kit with Eibach springs
2x 400 Lb Springs
2x 500 Lb Springs
Rear pillowball strut tops
The only thing required is front housings supplied by Veilside on NissanRoadRacing.com and front top camber plates
This setup will beat anything even triple the price and the ability to properly adjust shocks and change springs for another set by Eibach make this perfect.
Stack Datalogger $880
For sale is a STACK ST8952 Standalone Data logger with expansion module.
This Data logger has 8 inputs and monitors and records up to 20 channels at up to 50Hz a channel. This is a standalone system that doesn't have visual display but I can be added if you wish. The system also has an additional module with a further 8 inputs. This system also has a inbuilt telemetry capability.
Included in the sale:
STACK ST8852 Module + Loom
STACK Expansion Module + Loom
STACK Network Harness
STACK G Sensor ST791 Cost $530
STACK Lap timer receiver ST543 and Lap timing beacon - cost $500 needed to generate the track maps in the analysis software
STACK ST8990 PCAN-USB Download Cable
DATAPRO V6 Softare (The latest and greatest fully upgraded software enables you to use generic sensors instead of the expensive STACK ones. Pressure and temp sensors can be had from $20 and any sensor that outputs volts or is resistance based can be integrated using the custom sensor manager shown in the pictures below)
DataPro is available in 3 versions Basic, Semi Pro and Pro (math channels, custom sensor inputs, rainbow, import and synchronize external video feeds) - The Pro upgrade Cost $950
The performance upgrade pin has also been activated at a cost of $450 giving the predicative lap time function and brake bias.
Speed sensor gearbox pickup included
http://s28.postimg.org/trzif5ph9/a11.jpg
http://s28.postimg.org/ntlp4x6il/a12.jpg
http://s27.postimg.org/tpf4l07oz/image.jpg
http://s27.postimg.org/53t7guzn7/image.png
http://s27.postimg.org/up5fgpmur/image.jpg
http://s27.postimg.org/j1bdm5xpv/image.jpg
http://s27.postimg.org/g9s3vjz77/image.png
http://s28.postimg.org/y0z6k7mf1/image.png
http://s28.postimg.org/k4w05fwhp/image.png
http://s28.postimg.org/6uhc3ekot/image.jpg
http://s28.postimg.org/jj719c1fh/image.png
Permacool Oil Cooler thermostat $45
Oil Filter relocation kit $25
http://s28.postimg.org/kn4xqiq7x/a41.jpg
Please PM, reply in the thread or call 0499988821
