Horrible Miss R33 Gtst
Baldwin1993
ok guys so i know there is quite a few threads about this but there are also a lot of different answers, so I'm looking for something more accurate.
so i have a 1996 r33 gtst series 2 and a week ago it was fine. one day i got in it and drive it and every time i hit the throttle it has a horrible miss. SOMETIMES if i take it out the road for a drive it may be fine then later ill get back in it and its the same again.
i pulled the coil packs off and the fourth plug had water in it so i blew that out n put it back together with excitement thinking id have fixed it but it didn't. i didn't actually pull the plug out, just dried out the water around it.
please help me, this is doing my head in! :/
Cheers, Ethan!
Edited by Baldwin1993
not all places stock Bcpr6es or Bcpr7es. usually supercheap and repco wont but call them up and ask and otherwise they should be able to refer you to a place that will.
Beyond that, how do you have water getting into your coil valley area? this is not a good thing and worth sorting before you put in the new plugs...
Clean the coil valley out, clean the coil packs and replace the spark plugs. There's a youtube post for fix misfire on r33 gtr where you basically add some dielectric grease (headlight bulb grease supercrap has it for a dollar a pack) to the bottom of the coil pack where the spark plug pushes up into the boot. Worked great for me on several cars.
