Is It Safe To Do A Compression Test With A Broken Oil Pump?
Similar Content
By Doug 98 R34 GTT · Posted
Thank you both, much appreciated. Yes, 6k miles, not a typo lol. The underside, engine bay, engine, trunk, interior, etc., look great and super clean, has all the splash guards too. Not sure if you can expand the photos, but the dash pic shows the ODO. She looks brand new, inside and out, even has the original Nissan TV/DVD/Nav head unit; still thinks it's in Tokyo haha! I used to own a '94 MKIV Supra, sadly sold it years ago, but wow I love the Skyline so much! The R34 gets SO much attention here since they just became legal to import last year. -
I'm going to have to call shenanigans on the 6000 miles. There haven't been any R34s with 10000km on the ODO since the mid 2000s. Photos of the pedal rubbers, seats, carpets, etc required to even consider the possibility. At that many miles the underside should look almost completely new. The movement of the gear stick is likely to be 100% normal. As Duncan said, the differences from an auto may be surprising. It is a mechanical thing, not an electro-hydraulic isolation device.
By Dose Pipe Sutututu · Posted
Timing map only tells part of the story, I've seen a few cars where the CAS has been adjusted so you might see 12 at the ECU but at the motor you could be seeing 8 kind of thing. A S15 I converted from PowerFC to Nistune had just that, CAS was turned back to have less timing than the ignition map itself lol... "Choonered". -
By Murray_Calavera · Posted
But your running 1.6 bar of boost, is it still 12 degrees of timing at 1.6 bar of boost? Also, is there e85 fuel at the petrol stations in Dubai?
Register a new accountSign in
