What Are These Wires Going? / Rear Fuse Box/relays / R33 Gtst
It's 12 gauge Tefzel wire. Should be right for 20 amps. I've clamped the fuel pump wiring, it measured around 20 amps. I can't remember the exact figure, I did it a while ago now, but it was around 20 amps. Still, lots of good info in this thread now. I'll keep investigating and post back with what ends up solving the voltage problem. -
Maybe find the spec sheet and see what the resistance of the coil is, possibly it's not fried? Especially if you didn't short it -
No, that should not happen. As to what has happened....it's anyone's guess.
Currently have my engine out for a rebuild, and doing some other works on the rest of the car while it sits, like taking the steering wheel off to replace the clock spring and removing the wiring and button the previous owner wired in to the dash to make the horn work. My dash lights like the ABS, AIR BAG, HICAS, etc that come on when you turn accessories on as well as the climate control unit stay on when the ignition is off and key is taken out. Unfortunately Im not sure if this was happening before i pulled the steering wheel off and replaced the clock spring. Is this likely just something with the wiring that will be sorted when the engine is back in and everything wired up? Or could it be something from the wiring under the dash with the ignition? Thanks in advance
