Hi all,
Cleaning out the garage and i have the following available.
Located in Campbelltown NSW, Prefer pickup but willing to post smaller items at buyers expense
Negotiable to some extent but low ballers can eat a dick
Front and rear height adjustable camber tops. Bought them for a project that i later stripped and sold. Ball joints still tight, didn't knock when in the car. Includes the spanners i made for them and spacers. Also includes a second set of rear threaded inserts with an 8x1 thread from memory to suit the koni's i had in the rear at the time.
$300
Koni yellow adjustable front struts in s13 housings. Drilled to suit s14 knuckle. Travelled a grand total of about 200km.
$200
S14 front 5 Stud hubs, knuckles and LCA's, ABS $200
Tuneagent s13 toe arms $100
Xforce 3.5 inch universal cannon, new in box $80
R32 GTSt BM44 non abs master cylinder $90
Nismo LMGT3's, 17x9 +20 all round, ok condition, pretty nasty rash on one rear but not very deep, minor rash on all the others. No buckles or leaks,missing the centre bolt thingys. Come with near new 235/45 f and 255/40 r tyres
$1100
S14 manual diff, i think that makes it a 3.7? $50
S15 rear calipers, hand brake cables, $50
S13 manual cluster 170k on it, $20
S13 non hicas subframe and knuckles, I may even have some stock toe arms around if you want to fully delete hicas in your r32 gtst, $50
R32 drivers door, straight, black, paint not perfect, a bit scratched/scuffed, seals and trim a bit tired. Comes with glass and all wiring, window motor a bit touchy. No hinges, $50 ono.
http://s206.photobucket.com/user/badhairdave/media/Mobile%20Uploads/IMG_20140803_171152.jpg.html?sort=3&o=0
S14 front lca's, easy way to get some extra track and camber in your 32gtst. $120 ono
http://s206.photobucket.com/user/badhairdave/media/Mobile%20Uploads/IMG_20140803_171058.jpg.html?sort=3&o=1
Edited by badhairdave
    • Great discussion guys. I just have coil overs in my car right now. Ride is pretty stiff and everything feels very precise and accurate when hitting the corners. I started off with a high level and kept specimen.   the only item I feel I might need to adjust is my camber with control arms or a kit as I might want to tuck in my rims more so there is no rubbing. Otherwise I have not thought too much into it as quite happy with the setup. I think the bushings are all good still.    My motor is currently out now but I have got a nismo front strut bar to install. So that should help with body roll in front.    added a photo of what I started with before the modding or let’s say modernization of parts started. 😂
    • Thank you both, much appreciated. Yes, 6k miles, not a typo lol. The underside, engine bay, engine, trunk, interior, etc., look great and super clean, has all the splash guards too. Not sure if you can expand the photos, but the dash pic shows the ODO. She looks brand new, inside and out, even has the original Nissan TV/DVD/Nav head unit; still thinks it's in Tokyo haha! I used to own a '94 MKIV Supra, sadly sold it years ago, but wow I love the Skyline so much! The R34 gets SO much attention here since they just became legal to import last year.
