Flow Return Intercooler
Adham33
Just jap intercoolers only make around 250kws and that's not good for me
Sent from my iPhone using SAU Community
1. Hamish said "a good jap brand like blitz", not "just jap" (which is generally "Cooling Pro")
2. Where did you get that 250kw figure from? What will you be using the car for? Etc..
    • Ok, so we've had some (expensive) problems but nothing critical, thankfully. I get parts from FCP Euro in the states and in this instance I got 4 x genuine BMW cooling lines and 4 x OE quality oil lines (because they had no genuine stock). Well, turns out the OE quality didn't fit and the guys wasted a lot of time with them. Thankfully FCP has lifetime returns but the genuine BMW lines locally were $250 each! They also discovered my drivers side engine mount was totally dead and the replacement mount was $350. This sucks as I almost bought new mounts when I did my FCP order and I would have had both the engine mounts for less than this local one. So, I'm assuming at least another $1500 on top of the existing number. They did reassure me that the new (used) turbos looked good which was my main worry. Car will be ready for Monday pickup.
    • Forgot to add, that excellent economy was on street tyres, normal street alignment, I recall they were Kumho KU31. Current motor, with the silly alignment and tyres would go nowhere near those numbers.
    • And also, as small as the effect may be, the larger exhaust side places a lower restriction on the exhaust flow, even when off boost. When my bigger turbo went on you could hear the difference in the exhaust note at cruise (almost everywhere actually) and fuel consumption went down a little bit.
    • I got better economy after fitting a bigger turbo (when purely highway driving, Sydney to Forster, got down to ~8.3L/100KM), as it takes more throttle and RPM to get on boost.
    • Oops. Sorry mate. It is both excellent to hear and also surprising though. The amount of work required to (effectively manually, not on a production line) build a core vs your low retail price point is why I presumed that you were buying cores. But let's also be clear about what is meant by "build". At your price point I can't see you making cores from billet on a mill, even if CNC, or doing all the machine work on a rough casting. Surely the lumps of metal are sourced more or less ready to go from an Asian supplier, right? Maybe the same with shafts. I mean, you could turn shafts up yourself, but it's pretty slow going for items that are all essentially bulk order producable. I was always perfectly willing to believe that you assemble your wheels to shafts, fit up bearings and do all the balancing. I actually expected that you would have been doing all that even if the core did arrive from a supplier with most of that pre-assembled. Nevertheless, please accept my apology.
