Major Victorian Scammer- Jet2Nv, Jet31
copthis
Why anyone would get a new turbo inspected is beyond me. That makes no sense.
Why people would defend jet2nv sort of makes sense.
But why he had the other accounts makes no sense.
Something suss going on.
Closed.
So, I ask you, admins, #@funkymonkey #@Blitz #@R31Nismoid - Is this something you are prepared to let stand? Is he allowed to keep getting away with ripping off your membership with absolute impunity, after you banned him years ago?
Let stand? Really? No-one has PM'd or reported anything to Admin... Just a nice big war has broken out between two people.
Admin are now looking into it... Although very interesting you are trying very hard to make sure you're IP is hidden each time you log in.
Guest
    • Next up was from CAD🙃 work for making up some ducting. Transferred the template to some scrap 3mm aluminum I picked up and added some pinchweld with gasket to help with  sealing. The same process was used to cover the other large gaps. Made a bracket up to hold the water sprayer tanks (5L each for 10L total).  The pump for the water sprayers was installed where the battery used to be, which was relocated to the left hand side. While I was cleaning things up I decided to remake the aircup system mount. Before: which made more sense when i had a full boot trim and sub/amps After The boot feels and is likely more balanced now.
    • i'll never buy a wrapped car again, all the paint tore off my car when i removed the wrap. It had definitely sat out in the sun for way too long!
    • Thank you for the manuals. I actually need the full wiring diagrams since I want to build a full harness for my new setup with the Haltech Elite 2500. Any chance someone knows where I can get it ?
    • Oem std front sway and new oem end links mate   Rear recently moved to 24mm whiteline sway using the links that came with that
    • Hey mate just out of curiosity what front swaybar do you run and do still use the factory end links if you don't mind sharing that info.
