Selling Skyline R32 Gtst Black
r32lover
hi there people i am selling my nissan skyline r32 black gts t 1990 has a aftermarket intercooler its manual is still registered for another 6 months but has a canary on it
and i dont have the money to maintane it i have spent 5k on it i think its time to let her go
for the canary i coped on it was for:
1...replace windscreen
2...replace winder blades
3...change 4 tyres
4...adjust handbreak
Edited by r32lover
Honestly, I'd be doing one of two things...
1. Fix the defects because it won't sell with them still on the car.
2. Sell it on the Driftsales facebook group, but prepare yourself for lowballers.
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
