[Fs] [Sa] R32 Gts-T, Fresh Respray, Registered With 260Rwkw Neo 2.5L $11K
To add to that very useful summary, even in the race/rally r32 gtr I have good quality, new(ish) poly bushes everywhere because that is what rules require, and the handling is excellent. Of course, the car doesn't do many klm but I'd still expect poly bushes to last better in road use than sphericals (especially as I have a couple of klm of dirt road to stuff sphericals up) I would change the front upper arms to spherical if I was allowed to, because the poly bushes flog out often, but otherwise new bushes (and ball joints) and a good alignment can make a world of difference
Any chance you can get a Nistune board installed instead and set the speed limit to whatever your tires can handle? -
By GoHashiriya · Posted
