A Set Of Bc Racing Er Series Coilovers For Gtr32
Hi guys,
At first, I am currently located in Seoul, South Korea, so plz bear that in mind.
I have initiated my own coilover manufacturing business here so I am no longer needed of a near new set of BC Racing ER series Coliovers for my GTR32
It has been installed for nearly 2 years, covered approximately 28,000km since my GTR is a third weekend toy which I hardly drive thesedays.
I remember paying over $2,000 including an damping control extension kit for the rear but I have realized that BC has lowered the price drastically since then.
So I am asking for $1350 including Intl. Shipping to your destination in Down Under. (I assume the TNT express would cost roughly 250 ~ 290 Aussie $)
The coilovers have not been detached yet, but once the trade deal is confirmed, I can unstall them right away.
Many thanks guys
ie. BC ER Series coilovers (with extra reservoir) covered rougly 28,000km, 20 months old
Including damping controller extension kit
Rubber Mount (Not Pillow Balll type)
Spring Rates
F: 10.0kg
R: 8.0kg
Price: 1300 AUS Dollars including Intl Shipping to your destination via Paypal
