350Z Tranny To Rb30 Block?
So I’m having issues with my power steering. the obvious heavy and light and comes on and off randomly now it’s constantly heavy. I’ve read through forums regarding this issue and what I’ve gather is that it’s referring to hicas deletion. That’s the problem mine didn’t come with hicas. I’ve rebuilt the steering rack, pump, changed the bent hardline on the rack and taken out the solenoid to clean and loosen up the actuator, applied 12v to get it moving. Roughly checked the loom to see if there’s any damage to the loom and nothing. Now I’m checking the wiring. I’ve tested the wiring to the solenoid and it’s fluctuating between 0.07v to 0.03v. Does anyone know what it’s supposed to be reading? 5v? Anyone one know how this all works? Is there a fuse in between? What else is it connected to? How does it connect to the speed sensor? A resistor fried in the ecu? Please help. It’s been years Thanks in advance
