Rwd Stagea For Sale - Adelaide!
powerhearse
http://carsales.mobi/cars/details/1998-nissan-stagea-25t-rs-wgc34/SSE-AD-2739691
Selling the Stagea as I've bought myself an Evo 7 and no longer need the storage space - it's like the opposite of the norm!! :D
Anyway all details in the ad, yellow S2 RWD Stagea 131,500 km, stock except for 3" turbo back exhaust, hi flow panel filter and boost gauge.
Requires some paint work if you want it in show condition, but overall great condition; major service done and splitfires recently installed
Asking $9800 ONO
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
