R32 Wiring From Battery To Drivers Side
814k31
Hey boys!
Im looking for some help getting a wire from under the hood to inside the car.
Im wanting to do an amp install and everything else I have planned for and will be a breeze.
However I cannot find an opening anywhere.
I found a little rubber opening where the wire to open the hood leads however I couldnt find where it leads under the hood.
Any help?
I'm running a '94 GTR R32.
Cheers guys.
Ahh thanks man
I found the foam piece you're talking about
Although with the black circular plastic piece with the tube sticking out stuck there its going to be quite a task to get it though. :\
