Wanted R34 Manual Coupe Non Turbo
megaborg
hey guys, new to skylines and wanting to buy a non turbo r34 manual coupe
i have the cash waiting for right car. must have rwc and reg. or be willing to get an inspection done to show what it needs.
must be in victoria. and preferably near gippsland will travel for right car though
Edited by megaborg
Guest
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
