R32 Gts/gtst Weight Distribution
R32 SEDAN with RB25 & R33 box. 1450kg total with driver and almost empty tank.
Only things that would effect weight from standard coupe are 17" gtr wheels, gtr bonnet, gtr rear hubs.
870kg front (959lb./wheel sprung)
580kg rear (639lb./wheel sprung)
There's a weight bridge in oakleigh that will do it for you for $20
