Rb 20,25,26 Parts
chocky
Rb bits! Mostly rb20det!
Located in Devonport. Can freight at buyers expense.
Rb20det head, bent valves in 2 cylinders $150
RB20det cams(stock)$40 each
Stock exhaust manifolds $30 each
Turbo oil/water lines $30 set
Brand New dayco rb20det timing belt $60
Polished alternator and starter. $70 each
Rb30 rocker cover $10
High pressure power steer line. $30
Standard rb20det injectors $10each
Rb20det knock sensors $20each
Standard rb20det hydraulic lifters/buckets $50 set
Rb20det exh manifold gaskets x2 new $30each
Rb20det rocker cover gaskets. New $20set
Standard rb20det coilpacks $15each
3inch into 4inch blast pipe straight through exhaust, no cats, no mufflers. Suit a31 cefiro. Will suit others if your smart enough. $250
Standard rb20det inlet, $20
Rb20det fuel rails $20each
Thermost housings $20each
Heat shields, exh manifold $15 each
Rb30 5 speed. Clunks loud in every gear. $50
Rb20det throttle body, no sensors$20
Standard s15 struts with Lovells springs $150
Standard s13/a31 castor arms $100
Hicas steering rack, split boots. $80
R32 GTR Rb26 complete twin turbo setup. Manifolds, Standard garrett turbos, oil/water lines, dumps, etc. Minimum shaft play $450 ono
R32 GTRrb26dett Mines tuned ECU $280 ono
R32 GTR power steering pump $80
R32 GTR front diff $150
Heaps of standard rb20 bits and pieces floating around so just ask if your needing something.Don't be scared to make an offer! Need gone!0409402860
