Brand New Oem Coils Set Of 6 Mcp1330 2248-25U00 $320
By littlegee121 · Posted
Hi did anyone sort this out as I have the dual sbc type r and my display does not flash and I cannot set desired boost pressure as per the instructions. Only duty, gain and p gain. Or warning boost pressure and limiter. Is it just full boost and you only set duty, gain and p gain and then warning boost pressure and limiter? -
Hey could you send me the report. I can't PM you as I haven't reached the 15 post limit yet!
