Z32 Ecu In A S1
whitenight27
if it dose not make sense its because I was at work typing fast not to be caught lol.
I have a s1 c34 stagea and am looking to upgrade the ecu. I read hear a while ago that u could use a z32 ecu in the s1 so it could be nistuned. so I was after all the info on making it work. a guy hear in wa has a ecu but I not know if it can be plugged in to my existing loom. the stock ecu plug now is a grey plug
so yes I think it is called a z32 maf
The z32 maf is not an ECU. It's the air flow meter. I'm not a c34 guy but I believe it allows a higher flow rate before it hits cut compared the the standard maf sensor
I have heard that story too but I don't know anyone who has done it. You are looking for an ECU from an auto Z32 but it is far from a simple job and as I say I am not even sure that it will work. You could try emailing Nistune as I am sure they would know about it if anyone has done it.
Sorry I don't know much about the Nistune options either, but I do know a Z32 ECU would be a full wire in job which is a bit of stuffing around. You may well need the z32 AFM as well but getting the ECU in and wired is the first trick.
or swapping pins. but I am still finding out. according to a few tuners hear the triptronic has its own module to control that. so he said u will just need to find out if the auto shifts the same still. the awd is not affected as long as the signals to the awd module are right
Edited by whitenight27
The only other time I have heard of a 34 ecu in a stage a was in a thread in forced induction. A guy from the UK had it done, and the trans wouldn't shift properly. And heaps of power was missing"
I can't remember exactly but the title had something to do with t2 turbo,as apparently that's what his tuner fitted....
Anyway I'm predicting this will be way harder than you think. 4bidn1 has done a neo conversion so would know a thing or two about the neo Ecu's hidden traps.
yer I am talking with a guy in the uk about his s1 that was running a r34gtt ecu. trying to get all the info. if I can get a r34 ecu for bugger all I will try what a tuner hear said. to plug it in swap the cas wires and see how it runs if it starts. then take it for a slow drive to see how the auto is. if none of that works will just look as a decent piggyback ecu
    • But your running 1.6 bar of boost, is it still 12 degrees of timing at 1.6 bar of boost? Also, is there e85 fuel at the petrol stations in Dubai?
