Removing Turbo Timer
asps91
Hey there electrical techs! Need a bit of a hand with my r33 gtr turbo timer removal.
So my freshly installed adaptronic ecu was not turning off. I thought this was related to the turbo timer so i went about and tried removing it from the car. It is one of those timers that comes with a harness. This was completely removed however a couple if wires are still wired into the factory wires.
Now, if the ignition is turned of and on quickly.... Every second time the power to the ecu goes off. Super confused as to whats happening.
Any ideas? Thanks
