Recommended Tracking Device - App?
Marko R1
Hi guys,
I live in Sydney and was wondering if there are any other vehicle tracking services out there? I was a quiktrak customer until they ceased trading and I still have the quiktrak system in my car...can I possibly reuse this technology with another provider or should I simply remove the hardware?
What is the latest on quiktrak?
I was hoping with today's 4g and app technology that there are more options than over 5yrs ago :)
The ORIGINAL one did not. The last versions DID.
How old was yours ? If pre 2008 then it was spread spectrum radio. If later (after I lost $65k in contracts) then they were sim based.
Mine was 2004ish.
I do remember seeing the unit and it was a little thin black box with an aerial hanging off it, kinda looked like a funnny walkie talkie hence I'd say it was spectrum radio.
We're u a founder / shareholder of quiktrak? (Lost 65k)
I did a Google search but couldn't find much other than u being a distributor. There is obviously a gap in the marketplace for this solution as I don't really hear of ppl using these tracking devices anymore...why is that?
It's on this forum.
I was selling their product from 2002-2009. Was successful with it until it cost me a council contract with 10 ferries in planning to be equipped with a modified version of that system.
Self monitored systems took over in reality. $5 SIM card and a cell phone dapple of yanking your car up on a map.
Fleets use a variant system but the idea is the same. GPS location and VMS at the base.
  • 6 months later...
Self monitoring systems sounds interesting, can u recommend a particular vendor?
Hi Marko, did you find anything.
I have been looking for something as I am getting paranoid about spending a Shat load $s on mods and the insurance not covering the costs.
I want one that is wired in and I only want it if the car gets stolen and I can see where it is and report it.
They all seem to come with too much info, not wired in, fleet or base monitored systems
But I will keep searching :)
    • Euros are shitboxes man. My next car going to be a Lexus or Hyundai.
    • Maybe I used the wrong sandwich plate as well. Used one piece instead of two piece.
