Double Post Delete Thread!
By jacobzking · Posted
https://whiteline.com.au/front-and-rear-sway-bar-vehicle-kit-to-suit-nissan-skyline-r32-awd-9986-bnk009.html whiteline calls them a sway bar, the topic of this post.
