S A U And Wheel Centre Tech Arvo Wrapup
GTR-N1
Many many thanks to Ian Raymond & Craig Cameron for accommodating SAU Members for an illuminating and involved learning experience about wheels to-day!!!
Everyone present I think, seemed to be immersed in all the information that was on offer.
I certainly learnt a lot.
Great to see all these friendly Members' faces too.
Sycorb who had to leave early; other Members who could only arrive late - at least we had a happy medium, by having this on an afternoon for once rather than an evening.
Corinne (DIF):- you guys may not know that 3 of us present to-day became Members in 2007 due to her encouragement on a dyno day event at Brookvale. Seems such a long time ago that God_speed, Pezhead and myself all joined up that day! 'Twas good that you came Corinne.
Had a great time, and thanks again to Ian and Craig for the session. Thanks to Terry, and other execs who put the hard yards in organising it.
Also nice to know that good quality jap rims have a good reputation with the professionals. ;)
Great day!! Thanks to all the execs for organinsing
Big thanks to Ian and Craig for great info and great presentation always great to see ones passion for good quality products
Great to see all the usual faces and meeting new faces ready for the next one!!!
As everyone else has said, massive thanks to Ian Raymond and Craig Cameron for their hospitality and the information they provided today! Every one of our tech nights has been both informative and interesting so far, and today was no exception.
Thanks again to Terry for organising it too.
Thanks for the SAUNSW guys for organising the event with Ian and Craig.
It was good to finally put some faces next to the avatars and have some nerdy car chats with people.
Thanks to all involved.
Mark :)
Awww thanks Terry :) Was a good afternoon even though everyone was sweltering in the heat. (damn warehouses)
Very interesting workshop learnt some new things. Thanks to Ian Raymond & Craig Cameron also to the SAU exec committee to organise this. Good to see you guys are trying to keep true to the SAU club with these kind of events. They are great or all members new and even old. Can't wait for the next one. Sorry I had to run had to go pick up my sis. :)
A great session; aside from the heat I think the weekend afternoon format really worked well and I learned a lot - I think there was a good combination of basic and more technical information, and everyone I spoke to only had positive things to say. Thanks very much to Ian and Craig for their time, as well as Terry and the rest of the SAU Exec crew for organising it. It's stuff like this that sets the club apart from regular forums or FB-based groups.
Also Nick - loved the Clio! :)
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
    • by rotating the motor i mean to dismount the plate on the motor and mount it different
    • Sorry I meant to say, Is that $3,500 landed or is that just the sticker price in Japan?
    • Same (except for the R32 bit), my son is saving for his first car which he hopes will be a Kouki V37 GT with the twin turbo 3.0L V6.... kids these days! My first car was a Renault 16 haha 😄 Sorry for the thread hijack
