Rca Y Splitters. Are They Ok To Use?
Munkyb0y
I have an Android / WinCE head unit with front and rear RCA outputs.
The problem is the Android side of things only seems to output to the front RCA's (FL+FR).
(i can only select - left - right - two - off - for the android os sound output in the unit's main options)
The (crappy) WinCE side uses front and rear RCA's.
This goes for the normal speaker wires too.
Obviously I want to play music and media through the Android OS and utilize the dozens of awesome players and equalizers.
Plus this incarnation of WinCE looks and works like ass.
So I figured I only have one option.
Split the Front L RCA into 2 (Front L + Rear L into amp) and the Front R RCA into 2 (Front R + Rear R into amp).
I figure as long as left and right are separate, i can adjust fader (gain) at the amp. And freq for fronts at the amp too.
Will the sound quality, signal, etc suffer by using this method?
Is this a no-no?
    • don't do. Fricken typos. Make me look like the sheeple.
    • I could show you guys photos of wrap having been removed properly, and where the wrap was removed, paint underneath is perfect. Sections of the vehicle didn't have wrap on it, and in those areas, the paint work is destroyed because of how long it had been sitting in the hot QLD sun for many many many years. Wrap even still looked decent. Good quality wrap, and removing it properly shouldn't rip off the paint work, unless the paintwork was already shot to pieces before hand.
    • Any write ups on replacing the window motor?  I've never messed with them (or window regulators) before.   Ever since I've had the car, the driver window would roll down just fine, but most often I'd have the try a few times to get it to go up.  As soon as it started to go up, it always goes up smoothly and quietly.  Seemed like a bad switch.  But now, its stuck in the fully down position and won't come back up.  I get =12/-12V coming out of the relay/amp when pressing the switch up/down.  So the switch and amp are working.  Just a bad motor.  I've also applied 12V directly to the motor and nada.   Any help on replacing the motor?  Can the glass and regulator stay in, and only replace the motor?  Or not possible?  Thanks!!!
    • You are wrong. That's just Whiteline going along with the incorrect slanguage of the sheeple userbase. They are only correctly known as anti-roll bars. They are only incorrectly known as swaybars. They do do anything to prevent "sway". The swaybars that are fitted to trailler hitches do prevent sway. In the trailer. And they do not look like anti-roll bars. So, take your incorrect infopinion away.
