What The Hell Are These (Pics) - R34 Antenna And Bad Radio Reception
Lolrick
Hi all,
Recently pulled the stereo out and replaced it with a Pioneer unit, painting the black plastics at the same time. However, the radio reception wasn't great - when we held the harness (including bracket, Climate control, single din head unit and ashtray) before screwing it in we were getting amazing, loud, crystal clear reception. However, as soon as we screwed it all in, the clarity faded, though you can still hear the radio fine. We're going to try again this weekend and get a good ground going - we feel it may have been grounding through the antenna.
While the stereo was out, we found a pair of TV 'bunny ears' antenna (from the jap install with previous headunit that had TV function? The TV never worked for me).Also, there were quite a few proper connector plugs unplugged - is this where the automatic models would be plugged in? My vehicle is manual. I also found some RCA cables (L and R) that seemingly didn't fit anywhere. It seemed that when i turned the ignition 1 click when they were unplugged, there would be lots of whining noises coming from the dash. However, when they were plugged in, this seemed to subside - even if they weren't plugged into anything with output.
Curious, i opened up the boot and took off the little cardboard/carpet section between the boot and the rear seats, and found these things (pictured) near the rear speakers on the parcel shelf. I receive frequencies for Triple J 105.7 and Triple M 104.9, so obviously at some stage in Australia (vehicle imported 2004 i believe, 1998 R34 GT-T) i had an FM expander installed. There is a 'Diversity' plug/antenna thing behind the stereo i believe. Are these things antenna amplifiers, or are they to do with the Hicas? I have had no experience with this before.
Because of the RCA cables, (and whatever that thin blue wire is?) I suspect that the previous owner had amp and subs installed, and pulled out the power cables, when he sold (as well as the amp and subs - i own neither) because i can not find anything connected to the battery. If anyone could shed any light on what these things are, and possibly go all Sherlock Holmes and tell me what the previous owner got up to, it would be much appreciated! Finally, any suggestions on how to clear up radio reception is also welcome! will provide further information once i open it up again this weekend
Cheers,
Mick
I guess it can't be anything interesting then, which is really what i wanted to know. I have a pdf of the workshop manual at work, will have a dig around in this (on company time ;)
