Wrecking R30 Hatchback In Tasmania
do_a_skid
Am happy to organise a courier. I take it they are in working order? I'll be replacing the ball joints so just need to make sure its structurally okay (mine apparently were, but not good enough to replace joints without fatiguing the the area around to joint too much). Would it be possible to get a photo? Mainly interested in around the ball joint area.
Peter
0403306440
  • 5 months later...
    • Because it's rubbish, it got progressively better with each generation but still rubbish when you're pushing the car on the track. Some like it, most hate it.
    • Yeah, I presumed that the pic was of some other car, because of the F. Ikeya arms.
