Formula One 2014
tweety bird
Yeh, I have to say watching Alonso, Vettel, Kimi etc eek out the performance on the tyres is impressive. But frankly rather go back to watching them all rag on car lapo after lap and like of Lewis and co having ared hot go at each other rather than trying for 2 laps then backing off in fear of using too much tyre life
No problem, make them use their tread depth and wear....but making the operating window so small and temperature dependant seems to be a backwards step
Was trying to find a suitable 80s "turbo" decal for this thread. But couldn't find anything 80s enough.
Might sound different to V8s, but bring on the modern turbo era.
No Brian Hart stickers?
Hopefully Ferrari sort their shit out for next season
Nah, not so much.
    • Timing map only tells part of the story, I've seen a few cars where the CAS has been adjusted so you might see 12 at the ECU but at the motor you could be seeing 8 kind of thing. A S15 I converted from PowerFC to Nistune had just that, CAS was turned back to have less timing than the ignition map itself lol... "Choonered".
    • But your running 1.6 bar of boost, is it still 12 degrees of timing at 1.6 bar of boost? Also, is there e85 fuel at the petrol stations in Dubai?
