R32 Gtst + Parts
I have posted this in car parts instead of whole cars because the car is not whole :) Moderators please correct me if this is wrong.
For sale are the following items:
R32 GTST w/out engine or gearbox
- Diff still in place. Aftermarket steering wheel, gauges etc, Aus spec Tein coilovers that were 6 months old before the car was decommisioned approx 6 years ago.
- Interior still in tact but will need a cleanout
- Tyres old as f*ck but 80% tread at least.
- Paint in poor condition but will not be hard to freshen it up. Only rust is surface rust on roof sides and bootlid - will need a respray + fix a couple of minor dents. Boot lid needs replacing (was replaced ages ago as a wing-less bootlid but dodgy repair means rust under bog so it will prob need to be turfed. Has front Veilside copy bar
- Brakes were 80% new (DBA slotted + EBC pads)
- Early PWR vertical row intercooler
$2500
Garrett GT4508 Turbo (used) + CN Racing 50mm wastegate (brand new)
- Great condition, hardly used. Comp cover outlet will need pipe welded as it has been cut off where the hose could normally join
- Wastegate is brand new, never used. Throwing it in because IDGAF
$1500
RB25 Prepped Block with Forgies
- RB25DET Prepped block by Chilton Engineering (all the normal shit - acid/hot tank, decked, bored, honed etc)
- Eagle H-Beam conrods
- ROSS Racing Pistons
- Crankshaft has had the oil gallery plugs changed but no crank collar fitted
- Everything balanced etc
$2500
RB25 Cylinder head in pieces w/ Solid lifter conversion and cams ready to go
- Plain jane unmodified RB25 cylinder head that's been stripped and cleaned ready for porting (no valve guides or valves/springs etc)
- Supertech solid lifter conversion brand new ready to go into the head (This item I had listed for sale for $1800 by itself in this forum also but due to me selling all the other stuff I thought I'd mention it here as a complete ready to rebuild head instead)
- Camshafts custom Tighe Cams IN 280 x 10.4 and EX 290 x 10.4
$2000
If someone is interested in buying everything all together, I would be interested in negotiating a solid price that would be considerably cheaper
