R34 Gtt Rear Wheel Bearing Replacement
Chris32
So having to do this twice in a week, i figured the second time around I'll take some decent pictures for anyone else who wants to give it a go.
First time was with a second hand bearing from a wrecker, which wasn't much better than the old one. Although it 'felt' ok when it was off the car, once the wheel was on and you could get some weight / leverage on the bearing, it had plenty of play.
I sourced a new replacement from CBC Bearings here in Adelaide - (08)82617122
Part Number - NJ246AKIT - $114.58 + GST. This is a R34 specific bearing, with the tab for the handbrake as per the pictures.
You'll need access to a bearing press to push out the old hub and press it onto the new bearing. The locating pin for the handbrake bolt will alos need to be punched out and installed in the new bearing
1) Crack the wheel nuts and jack the car up safely, using axle stands. You'll need to apply quite a bit of force to undo some of the bolts, so you don't want the car coming down off the jack onto you. If you can't manage this, I'd stop reading now and take it to a mechanic! post-493-0-00343400-1383800671_thumb.jpg
2) Remove rear wheel and slide under the car for some added insurance if it all goes pear shaped.
3) Remove the brake caliper - 2 x 17mm bolts. Support the brake caliper so it doens't hang from the brake line. See pic for location of bolts.post-493-0-76587200-1383800715_thumb.jpg post-493-0-79272300-1383800735_thumb.jpg post-493-0-66181800-1383800765_thumb.jpg
4) Remove the brake rotor. If it doesn't budge, make sure your handbrake is not on, as this will hold the rotor on. It should come off easily, but might need a light nudge with a rubber mallet. You'll be left looking at the handbrake assembly and the hub as per pic. post-493-0-12556600-1383800821_thumb.jpgpost-493-0-12556600-1383800821_thumb.jpg
5) Remove the handbrake assembly. Take plenty of pictures showing the orientation and location of all the springs. Get undernreath and take some more pictures, as its a pain the frist time you put it back together. You can see the retainer springs in the picture, unclip these and it all will fall apart and come off. post-493-0-83657200-1383800846_thumb.jpgpost-493-0-71754400-1383800889_thumb.jpgpost-493-0-71754400-1383800889_thumb.jpgpost-493-0-25965200-1383800925_thumb.jpgpost-493-0-13451100-1383800955_thumb.jpg
6) Remove the split pin from the driveshaft and undo the big nut. I think its 32mm. Mine was very loose, leading to the bearing failure the first time around. Push the driveshaft back into the hub - this allows you to access the 4 19mm bolts located at the back of the bearing which hold it to the suspension. post-493-0-09633300-1383800981_thumb.jpg
7) Undo the 4 19mm bolts located at the rear of the bearing. You might need to push the driveshaft back while locating the socket. These suckers are pretty tight, so be careful not to smash your knuckles when the let go! post-493-0-00074500-1383801053_thumb.jpg post-493-0-66939700-1383801019_thumb.jpg
8) Undo the large nut behind the bit that the handrake springs clip onto. I think its 24mm. This one is also plenty tight. post-493-0-82425000-1383801086_thumb.jpg
9) The bearing should now slide off the driveshaft and leave you looking at the driveshaft and where it all locates. post-493-0-52797600-1383801217_thumb.jpg
10) The old hub needs to be pressed out of the old bearing and pressed into the new bearing. A trip to my favourite workshop with a bottle of JD's saw this complete in around 15 mintues. post-493-0-12391100-1383801253_thumb.jpgpost-493-0-57173500-1383801296_thumb.jpg
11) Slide on the new bearing to the driveshaft, and locate in the correct position. Locate the large handbrake bolt and then locate the 4 bolts in the back, do them up finger tight to make sure its all located correctly, then tighten. post-493-0-52907000-1383801335_thumb.jpgpost-493-0-30910000-1383801371_thumb.jpgpost-493-0-20427700-1383801422_thumb.jpg
Assembly is basically the reverse of pulling it apart. Remember to tighten that big nut up on the driveshaft, as that pulls the bearing toghether and keeps them happy! post-493-0-64751000-1383801469_thumb.jpgpost-493-0-66844500-1383801509_thumb.jpgpost-493-0-55101500-1383801549_thumb.jpg
Any questions, ask away
Chris
  • 3 months later...
Fantastic guide! Just thought I would mention though as I have been following your guide to do my rear bearings today, the axle nuts are 36mm, handy to know before you get it to that stage, especially if it's your only car and you don't own a 36mm socket, and I believe the nut that holds that handbrake assembly pin is 27mm, not positive but most socket sets have both. I also found I had to undo the bolts holding the drive shafts to the diff and move the whole shafts to get enough clearance to safely undo the bearing/hub bolts without risking rounding the heads, different height sockets perhaps. So far in my experience, the axle nuts have been the tightest, yet easier to undo than the nuts on the handbrake pins, not as much access to those, at least not when lying down with the car on stands.
I personally am going to be attempting to find torque values in the workshop manual for as much of this as i can as thats the way I like to do things. For anyone else that cares, the axle nut is torqued to between 206 - 274Nm, caliper mounting bolts I assume to be the same as the fronts being 152 - 154Nm (manual only lists fronts), drive shafts I am not quite sure which I have or what the differences are yet, something else for me to discover but for shafts T82CT82F the torques are 35 - 44Nm and for shafts Z100D90F the torques are 64 - 78Nm. If it helps, the tailshaft to diff flange bolts are torqued 55 - 64Nm, so i guess if your axle shafts have larger bolts than those, use the Z100 specs, if smaller, the T82CT ones. The torques for the handbrake pin nut and the bearing bolts dont appear to be listed in the workshop manual so i guess i will just rely on standard torque settings that i can find for those, but i cant do that until i get the thread sizes of them..
Cheers, Kent
  • 7 months later...
    • I don't know if this is accurate. The EPC places the EPS control unit somewhere in the engine bay or somewhere in the interior near the firewall, presumably because the things it's controlling mostly live up in the front of the car unlike HICAS which has a whole steering rack on the rear axle to handle. @D.phantom The R32 GTR manual actually has more than I give credit for talking about the non-HICAS cars: You can probe the pins on the diagnostic connector directly to read the EPS solenoid voltage as far as I can tell following the flow chart.
    • Hi all, so I bought a very low kms 2019 Q60s in Nov 2022 and have been driving it stock for 17 months. The power from the VR30DETT has been a little scary as these cars did not come with a LSD. Although the ECU does well with compensating the lack of LSD by using automatic braking on different wheels when there is lost of traction etc, it does not really give me much confidence to push the car harder. Further to that, the car feels quite boaty especially around sharper corners or roundabouts - it would seem like the wheels are lifting on one side. These engines are also very prone to heat soak as the heat exchanger is tiny. I felt this during the heat wave in WA over summer even in normal driving. Gear shifting in the Q60 is also something that I hated - it's quite harsh at low speeds especially in traffic.  I recently purchased a set of f&r sway bars, rear diff brace and a heat exchanger from Z1 in US. Here are my thoughts 1) Rear diff brace - no more wheel hop when accelerating quickly. wheel spin still present but manageable comparing to before. Gear shifts are now smoother, you can still tell its shifting etc but you dont feel the harshness. I would highly recommend this mod, and it should still be on sale at Z1 at the moment. 2) Sway bar - there are 2 settings for this F - 114%/165% increase in stiffness over stock and R - 138%/214% increase in stiffness over stock. Currently I am on the stiffer settings. The car feels very planted. Due to the weather over here I have not been able to test if i need to reduce the stiffness. So far it's much more comfortable to drive over stock as you dont feel like your car is lifting up and in fast turns you can control the car a lot better while turning left and right in quick succession.  3) HX - the Z1 HX has a much higher capacity and surface area (up to 200% or something). Again with the cooler weather it's a little hard to tell. I went with the Z1 HX due to the price, size and colour (black). You can't see the HX through the front bumper. There is a cheaper brand but it was smaller and the rest were more expensive which i didnt think was worth the extra since I won't track this car much at all. All 3 mods were easy to install, all plug and play. Note of caution, the front bar needed to come off for the HX to be installed.
    • A is the HICAS CU.  As far as I know, there are no other modules located at A in a car with HICAS, so it is fair to presume that F is the variable power steer module for non-HICAS cars. Same location, give or take. Makes sense - the wiring loom for the HICAS cars has the speed signal, power, solenoid drive, etc wires all present there - so why move the module and have to upend the wiring loom?   Having said the above though, it may be the case that F is further down in the rear guard - it's hard to tell. In which case it may be something else. Yes, it is the multi-pin plug next to the under dash fuse box. Top left corner. Can't miss it. Be very careful though - use insulated probes to poke around in there so  you don't accidentally short 12v to ground or an ECU input etc etc.
    • They didn't. This is their comments; I'm not sure why they don't have the OEM specs.
