Rays 57C6 18X9.5+20
OTR
Hi Guys,
We have a OTR Limited Edition Rays 57C6 arriving in about a weeks, these are currently not available anywhere in the world in this colour and offset (unless the US copies us:))
Gramslight 57C6
Colour: Matt Black
Cost: $2000
Package with Achilles 123S 235/40/18 or 265/35/18 + Rays Nuts + Hubrings for only $2700
(Delivery fitted and balance with tyres about $100)
Pictures of actual colour will be loaded when we receive the wheels
