Hks Gt2835 Kai Turbo Kit (For Ecr33)
89CAL
Up for sale is the HKS GT2835 KAI Kit I have been running on my car for the last few years. Kit was fitted around 2010 from memory and only problem I have ever had is it not living up to the performance of the Pro S that came before it
This is still a great streetable turbo if you want something with minimal lag and decent performance. I was getting 18psi at just over 3000rpm and I have 3' intercooler piping which probably added a little lag. Made a pretty safe 255rwkw on my car.
Included in the Kit is:
- HKS GT2835 KAI Turbo (0.84 rear housing, Surge slotted front cover + non surge slotted cover I had made up)
- Alloy intake pipe with ports for BOV and cam breater (Hoses for these in pic are not included)
- Braided Coolant and oil feed lines with fittings + Banjo's etc
- Direct bolt on to your Nissan style dump pipe
- Hose clamps + HKS silicon joiners for intake pipe and turbo compressor outlet pipe
- Can include Z32 AFM and new K&N Pod filter (old one pictured)
- Adjustable wastegate actuator
Turbo has minimal shaft play and I have never had a problem with it. Still in good condition. Only reason I'm getting rid of it is because I have built a new engine and have gone bigger turbo and external gate.
PM Me if you have any questions.
Starting price is $1800 but I'm open to offers, as long as they arent to low
Located in Mackay, Queensland
These kits sell for nearly $4000 brand new and this kit is still in great condition. All braided lines were P-clamped and wrapped so have not rubbed or been damaged in any way. Car serviced every 5000km with Motul 8100 X-Cess synthetic oil, and Proper coolant has always been run in the car.
Edited by 89CAL
  • 2 months later...
  • 2 months later...
    • Full results via link below https://docs.google.com/spreadsheets/d/1inu1mRRO0WjV2-3vGYsjnmYggVOzmApWOby68GwPGcI/edit?usp=sharing
    • Have I not posted since 2022 - wow. Yes, it's pretty much finished mechanically. I'll probably sell it soon as the old man is 80 in November, so 99% he won't ever drive it again. I don't really need 3 GTR and I haven't driven any of the GTRs since September - Correction, once drove my 33 earlier this year on Australia day. All of them have been like this since then.
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
    • Anyone here know the answer?....missing since the w/e...
    • Google tells me that's a Japanese Rat Snake... 2m long? Man I think Australia has traumatised me to think all snakes are dangerous unless they're pythons. Also... "16 years later..." is that a record on SAU @PranK?
