Eoi: Om.350
Mr 20Valve
Hi all,
Looks like it might be time to sell the M35 unfortunately, so just putting it out there to gauge interest...
Here's the details:
2002 NM35 250t RS Four
88,000kms
QX1 white pearl
M35 Dayz bodykit & rear spoiler
Impul ECU
Blitz NUR 3" stainless steel catback exhaust
Heatwrapped Scotty dump & catted mid pipe
Inlet runner spacer
Blitz panel filter
HDi front mounted intercooler
Turbosmart plumb-back BOV
2 x oil catch cans
Transgo shift kit
LSD rear diff (no HICAS)
Tein coilovers
Whiteline front & rear swaybars with HD rear links
Daleobrace front lower chassis brace
Ox Motorsport rear chassis brace
SPC rear camber & toe kit
Hardrace adjustable front upper A-arms
Superpro front caster bushes
350Z 'Track' Brembo gold calipers with QFM pads & slotted DBA rotors front & rear
Gloss black 19" x 8.5" Rota Grid wheels +25 offset
Engine oil cooler & power steering cooler
Scotty coolant bypass & bleed valve
Nismo thermostat
Samco silicone radiator hoses
Boost, engine oil temp & pressure, transmission temp gauges (factory triple gauges also)
HKS OB-Link hooked to 6" Android tablet mounted in factory pop-up screen location
Alpine Double-DIN touchscreen DVD headunit with Bluetooth & Satnav with reverse camera
DTV-B TV Tuner using factory antenna
Brake wire cut mod with switch
Recently replaced O2 sensor, AFM (old p/n), front lower ball joints, front hub bearings, rocker cover gaskets (both), Philips D2R headlight globes, battery, Attessa pump
March '14 rego
Will have to take some more pics I think...
Daylight robbery. I'll give you $5k and not a cent more :ph34r::teehee:
What an absolute f'ing steal. As if you cant fit enough baby seats in it so you can keep it!
A mate at work is looking for a new car and we are trying to talk him into getting a stag, ill show him this tomorrow and hopefully he'll check it out if you haven't sold it already. If I had the cash I'd just buy it and have two! Palm my shit-spec one off to the Mrs.
